Question about Motorola Mobility HS850 Consumer Headset
Need to pair up my BLUETOOTH # N136 headset with my Razr V3 phone
    Sergeant:
  • 239 Answers
If you need the code it should be 0000
could also be
6789
9876
4321
1234
9999
hope this helps
please rate well
Posted on Mar 06, 2009
NEED TO PAIR BLUETOOTH HS850 TO RAZOR V3
a With the headset’s boom closed, press and hold the Multifunction Button E until the headset indicator turns on (about 3seconds). The headset indicator turns on.
b Release the button, then open the headset boom. The headset indicator remains on.
2. Perform a device discovery from the phone. 3.select motorola hs850 and click pair 4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone. The device ID is now stored in the phone’s memory. Pairing is successful when the headset indicator flashes 10 times rapidly.
Feb 07, 2010 | Motorola Mobility RAZR V3
I can't my new bluetooth headset to work on my v3 razor phone.
You probably need to do pairing again. Watch the video on how to pair RAZR to the bluetooth headset on www.HandBookLive.com. The direct link to this video is http://tinyurl.com/aprhqp
Apr 07, 2009 | Motorola Mobility RAZR V3
BLUETOOTH MODULE NOT ATTACHED
you need to switch on bluetooth headset with battery charged enough. also you need to put bluetooth in search mode to pair it with phone. see manual which came with bluetooth to get it in search mode.
Jan 01, 2009 | Motorola Mobility RAZR V3
HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
Pairing my Motorola Razr with my Motorola H12 Bluetooth Headset
-put the headset2.gif in the covered charger (not plugged in)
-hold down all 3 buttons for at least 10 sec
-leave headset in charger (unplugged) and enter in 0000 when prompted for pin.
Sep 04, 2008 | Motorola Mobility RAZR V3
How to connect the bluetooth??
I used this Motorola Bluetooth manual to connect my Motorola N136/HS 850 to my LG PM 325 phone. In the attached manual: Go to "using your headset" - "linking your headset and phone" and follow the instructions. You may need to revise the steps slightly to fit the functions of your phone. I followed steps 1 and 2, skipped step 3 and instead found the bluetooth icon on my phone, selected "add new", then selected "searching and pairing" and allowed the phone to search for and pair my bluetooth device. The Motorola Bluetooth device appeared on the screen of my phone within seconds as "Motorola HS850". I selected the device on the screen of my phone and followed step 5 entering the pin code "0000" and selected "connect" on my phone to begin using my bluetooth. I hope this helps someone. Use the following link to access the manual: http://www.usersmanualguide.com/motorola/accessories/bluetooth_wireless_headset
Aug 05, 2008 | Motorola Mobility Bluetooth Hands-Free...
Bluetooth handfree not working
Verify that your Jabra BT headset is turned on. You might need to "discover" the device as well.Your RAZR should have instructions on how to pair devices.
Apr 30, 2008 | Motorola Mobility RAZR V3
Bluetooth problem
try resetting the phone and pairing the device again and see if that helps.
Mar 12, 2008 | Motorola Mobility RAZR V3
Motorola Mobility HS850 Consumer Headset Logo
247 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
