Question about Dell (H5195) Laptop Cooler, CPU Fan, Cooling Fan
Cool Utility to get Dell Inspiron 1300 CPU/Fan?
I don't know why DELL doesn't have a utility you can use to read the CPU/Fan Temperatures of you DELL Laptop. I have an Inspiron 1300 and this little utility works perfectly. It even allows you to control the Fan speed.
Get It Here: http://www.laptopbattery-usa.com/dell-inspiron-1300-laptop-cpu-fan-p-1244.html
He even has a command prompt version you can use. There is a full compatibility list of all the DELL Notebooks that this utility will work with.
  • Art Ellison
    Art Ellison May 11, 2010
    Is this a problem?
  • 561 Answers
You can also try this one. Has worked great on many models for me: http://www.diefer.de/i8kfan/
Posted on Dec 30, 2009
Dell inspiron 1420 cpu upgrade ???
There are very little things that you can upgrade in an laptop. The processor that you have on your laptop is top end processor in its family and the thae best you can do is to go for a faster core2duo as any other processor will not fit on your laptop motherboard.
Contact your system manufacturer to know about compatible processor for your laptop.
Nov 26, 2012 | Dell Inspiron 1420 Motherboard - KN548
I have a Dell Inspiron 530. Was getting 2 quick beeps on start up and loud fan noise. I replaced the cpu fan but the one I bought did not have the right plug for the motherboard connection. I had to modify...
This model (as well as many other Dell desktops) has a DUAL SPEED CPU fan. If the motherboard detects that the CPU temp is running hot it will increase the speed of the CPU fan to lower the temp of the CPU. You should do a Google search for the correct CPU fan and purchase it and install it back into your computer.
Aug 28, 2011 | Dell Inspiron 530 Desktop Computer
I have dell inspiron 1525.I am from India. I have two problems. First I have a sim card slot in my laptop and ai don't know how to activate it. My other problem is serious one. My laptop unexpectedly...
Dell has a series of tests for a system's hardware called the PSA+ Diagnostics. You can run these tests by performing one of the following actions:
  • Hold down the key while pressing the power button.
  • Turn on the system, press at the initial Dell™ logo screen, and select Diagnostics from the boot menu.
  • Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message Diagnostic boot selected displays. The system then launches the PSA+ Diagnostics.
  • As for the laptop shutting down, that usually indicates your CPU (Central Processing Chip) is overheating. This is caused by dust or defective CPU fan or heat-sink.
Jun 10, 2011 | Dell Inspiron 1525 Laptop
I have a Dell Latitude C-610 and I never have seen the fan move even when the computer has been on for over an hour. The computer is very sluggish but doesn't completely lock-up, or shut itself down( as I...
If you are concerned about the CPU temperature you could try installing a temperature control utility from here
I have used a similar program designed for toshiba laptops and that one was very useful. I can't guarantee the performance of this one for Dell but it's worth a try. It should give you a reading for the CPU temperature and the ability to adjust the fan control temperatures.
Mar 24, 2010 | Dell (5P255) Motherboard
Dell inspiron 1300 won't reboot. HELP!!!
Your Hard Drive may have failed. to be sure. enter setup (F2) then run the hard drive diagnostic utility. a scan can take up to an hour or more and will tell you if your hard drive has failed. if it has you will need to replace it and reinstall your operating system
Apr 21, 2009 | Computers & Internet
Dell inspiron 1300 laptop
There are individual tiny switches under each letter. When the letter is pressed it sends an electrical signal to the keyboard controller and the CPU to register which key was pressed. Liquid under the keys will short out the switch so it does not send out the signal any longer. You need to get it repaired by the manufacturer or local PC repair shop.
Don't forget to rate this solution.
Jan 11, 2009 | Dell Inspiron 1300 Notebook
Slow Cpu speed
Check in the BIOS to see what processor is rated at (upon power-up of laptop hit F2 key to enter setup menu). Depending on what model Centrino you have, the speed rating should be at around 1.2 GHz or better. If speed checks out in the BIOS then run diagnostics on laptop to see if the motherbrd has a bottleneck issue. To do this, hold down the <FN> key and then push the power on button. Problem could be either your processor or motherbrd.
Sep 14, 2008 | Dell Inspiron 1300 Notebook
Laptop running hot - Fan cycling on and off every 10-20 seconds
My guess is that CPU fan, it there is one, is not working properly and your computer is heating up. Is it turning off, too, occasionally after a period of time? Suggest a new CPU fan.
Jun 14, 2008 | Dell Inspiron B130 Notebook
Dell (H5195) Laptop Cooler, CPU Fan, Cooling Fan Logo
651 people viewed this question
Alun Cox
