Question about Comet BXD2527 Pressure Washer Pump
Comet 2700 psi, Chemical fitting leaking
I have a pressure washer at work and the bearings inside the pump locked up, I replaced the 6208 and the thrust bearing, After putting this back together, I seem to have pressure coming out of the chemical port, enough to blow the chemical hose right off the machine, I was wondering if anyone had thoughts on this. Thank you.......Dan
5 Suggested Answers
  • 60 Answers
SOURCE: pump problems
Are you only using gravity to feed the machines. The law of gravity is that, for every foot of elevation you will get 2 PSI ( pounds per square inch) of pressure. You can figure out the minimum volume that the manufacture requires and make sure that amount is being furnished to the machines. You will probable need to install a pump prior to the machines with a regulated return line to keep the proper amount of water running for optimum performance. Its very hard on the machine not to have the proper volume of water. So to answer your question, i don't believe you'll be able to get 9.5 GPM that the three machine need by simple using gravity. I hope this helps
Posted on Dec 13, 2009
  • 56 Answers
SOURCE: I have a Generac MC660 pressure washer with a
This is a Help forum but you should be able to find a service dealer from Comet. Here is a link to their web site. LINK
Posted on Jan 26, 2010
  • 68 Answers
SOURCE: It will not dispense the soap.
You need to adjust the nozzle on the end of the lance so the machine will draw chemical at low pressure.
Posted on Apr 21, 2010
Testimonial: "Thanks for your help, I will give that a try."
ftw1952
  • 10319 Answers
SOURCE: Low pressure when running.
basicly you can review all these videos and learn how to repair your pressure washer easily. Most have the same valves as shown were the hosses attach to
here is the link to many videos to view below
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4GPCK_enUS397US398&q=pressure+washer+repairing+you+tube
Posted on Jun 18, 2011
Why detergeant for homelite 2700 pressure washer only works with blue tip?
The chem venturi relys on low pressure to function this is specifically the blue nozzles job, to create a low pressure for the venturi to work.
otherwise you will be wasting chemical the entire time you are using the cleaner.
Hope this helps:)
Brad
Jul 14, 2014 | Homelite For Excell - Pressure Washer Pump...
B&E pressure washer w/ comet 3540 pump
Things to check:
1) is water coming out of the bottom of the pump or is the oil in the crankcase high level and milky yellow. If so your seals are bad.
2) Your check valves might not be seating properly. A couple of fouled check vavles will cause either no pressure or pulsing pressure. A good inlet water strainer keeps foreign matter out of valves. But valves do wear out and get build up that keeps them from working right.
3) Your unloader valve might be worn or fouled. Bad unloader would usually show as low pressure ( but more than hose pressure) or low volume out the trigger nozzle.
Valves are your most likely problem.
Feb 17, 2014 | Comet Pressure Washer Hw3540s Triplex Pump...
Comet tw 5050 mix oil and water
what you have is a bad seal or a crack within the pump crack more common if any water was left in it during the cold winter
Jun 22, 2012 | Comet Pressure Washer Tw5050 Triplex Pump...
My GDX 2525 will not pressurize water. I have tried adjusting the calibration knob on to without success.
It could be that the linkage between the engine and pump is broken. Try the key on the drive shaft. This is a piece of metal that locks the pump shaft and the engine shaft. If it still pumps water the problem probably lies elsewhere.
Jun 08, 2011 | Comet Pump Pressure Washer Pump 2.5 Gpm,...
Craftsman Pressure Washer 580.752160 reagent/chemical not being dispensed when wand in low pressure position.
It is very common for the chemical injector valve on these to get gummed up from residual soap sitting in the valve. To clean it follow the chemical hose back to where it attaches to the pump. There will be a hex headed hose barb attached to it. Remove the barb from the pump. Underneath it you will find a spring and a ball bearing. Rinse the parts thoroughly and reassemble. You should also check the chemical strainer that goes into your chemical bucket. They can also become clogged and should periodically be cleaned.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 07, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Foaming in pump oil window
I dont know which comet pump you have, but it is just easier to get a new pump from one of the pressure washer companies on the internet and they sell them on ebay. You can also probably get a better pump that will fit your engine as well. Also, have you tried just changing the oil and not fill it too full? On my 5000 lb washer, if i fill the oil too high when I change the oil, it will foam some. Hope this helps you, Rick
Apr 27, 2009 | Northstar Pressure Washer 3000 PSI
Comet BXD2527 Pressure Washer Pump Logo
142 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
