Question about Whirlpool Washing Machines
Whirlpool top load washer gets stuck on spin and stops
The model is ESTATE by whirlpool corporation. Everything works fine then as soon as rinse cycle end, the whole machine stop. don't hear the timer, no sound.
  • 163 Answers
Your lid switch is most likely bad.you can che.ck this by taking two screws from face of machine and flip face back.you will see a disconnect plug on machine that goes to your lid switch.unplug machine and unplug disconnect at top of washer under the face,you will need a jumper wire to put in 1st and 3rd hole in your disconnected.plug machine back in and see if it will go into spin.you can also put your finger on lid switch and push in on it and if you dont hear it clicking or if you dont see the finger to push in then it is definately lid switch.
Posted on Mar 06, 2009
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
My Whirpool Estate washer will not rinse spin or drain
The motor turns in one direction to wash and the other to spin. If it will not spin I feel sure it's a bad motor.
Please rate solution
Sep 04, 2009 | Whirlpool Washing Machines
Whirlpool Estate Washer won't drain and won't work
Need a complete model number to help you. Access to the parts varies with different model numbers.
Aug 30, 2009 | Whirlpool Washing Machines
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stuck on rinse cycle
Your water valve is bad or the cold side of the valve is stopped up with sediment. Clean the water valve inlets. If that does not correct the problem, replace the water valve.
Jun 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin heavy loads
you need a new transmission it will slowly get worse until it stops working
Dec 23, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal De
