Washing machine not using detergent...
I'm re-posting this, hopefully into ''Washing Machines'', as I managed to get it into ''Dishwashers'' before...Doh!
I'm hoping someone can help with a solution to the following...
I have a 2nd-hand Servis Easi-Logic 1300 that has just finished its 1st wash cycle with me. However, none of the detergent (powder) in the drawer was used! The fabric conditioner was taken ok. The person I got it from has gone on holiday, so I'm unable to ask them - though as far as I'm aware, it was working fine & they're a friend, so wouldn't ''do the dirty(!)'' on me...
I'm in the UK & aware that the company closed down last year, & have also been unable to find a manual - any hints on that one?
With thanks for your time & consideration...
  • raeabbie Feb 13, 2010
    washing powder is stopping in the tray, and turning into a wet blob it doesn't seem to be moving from the tray when the machine is on
  • 15,935 Answers
Www.diplodocs.com
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
What type of laundry soap does it use and how much per load?
You did not post any info on the make and model. The front loading type of washing machines MUST use "HE" types of detergent. This is because a front loading machine causes suds and regular detergent is not made for reduced suds. The best laundry soap according to consumer reports is Persil. You don't need very much either. Most people use way too much detergent.
Jan 12, 2017 | Washing Machines
Tip
Washing Machine Detergent
There are many questions about the type and the amount of washing machine detergent that is needed. Whether you are using a top loading washing machine or a front loading washing machine it does make a difference as to what and how much detergent to use.
Generally speaking a front loader washing machine will need to have less detergent then a top loader washing machine. Combine this with the water savings of the front load washing machine and you will get a substantial savings. However the front loading washer may be much more sensitive to many detergents. The recommendation of many manufacturers is to use HE detergent. This is designed to give less suds then many other detergents.
This is true but the use if the special detergent is not necessary. With the front loading washer you can decrease the amount of detergent used and still get great results. With warmer water you also can get better cleaning from less detergent. If you want you can also mix your fabric softener with the detergent and the fabric softener will keep the suds down for you.
If you have a top loading washer then you may want to experiment with using less detergent then you have thought would work in the past. By using warm of hot water you also can reduce the amount of detergent used and get great results.
Today’s high efficiency washers are very effective clothes washing machines. You can wash clothes with far less detergent in these efficient cleaning machines. Remember that the new machines are very sensitive to excessive suds and will even stop to allow the suds to go down before continuing on. More is not always better and with the washing machine of today, more may make it take a very long time to wash that load of clothing.
http://www.fixya.com/support/r4312694-washing_machine_maintenance
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
http://www.fixya.com/support/r3867591-washer_troubleshooting_water_not
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
http://www.fixya.com/support/r4356970-clean_washer
on Mar 17, 2010 | Washing Machines
I get detergent marks especially on dark clothes.What causes this?
wrong type of detergent . most do not recommend powders anymore .
Sep 17, 2016 | Washing Machines
Hi I have this error displayed in my machine. Can you tell me what causes this? Could it be because we use too much washing powder? Thanks
You did not post the error BUT if it is a front load machine you must use detergent that says "He" That detergent wont produce a bunch of suds.
Jan 10, 2016 | Washing Machines
Why dishwasher shows a AE blinking and has a lot of foam in the bottom of the dishwasher? what does it mean and what should i do ?
start to use the proper dish washing detergent for machines ( not normal washing up detergent)
Mar 28, 2015 | Dishwashers
Suds leaking from detergent drawer on brand new Bosch washing machine
Use high efficiency detergent that s more concentrated. It uses MUCH lesser detergent VoLUME than conventional. The detergent has "He" letter on the bottle. And usually with FULl load it uses only about 150+-cc ( my cup is on 3marked level provided by the detergent bottle) Hope this helps! Robert Calgary, AB
Dec 13, 2013 | Bosch Washing Machines
Soap is not completely washing all the soap powder away.
Stop using the powdered detergent. It has a reputation for clogging up machines and pumps. ALWAYS use the liquid detergent.
May 28, 2012 | Electrolux Dishwashers
Suds in washer after quits
Be sure to use a detergent made for dish washing machines, not regular soap used for hand dish washing. Hope this helps!
Jan 06, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Same problem with our LG Tromm
I had the same problem with my LG Tromm and was ready to throw away every one of my towels they were so rank smelling. As a last resort I filled the detergent area with one cup of white vinegar and ran a load through on hot. Then I washed them with just a tablespoon at most of detergent. They came out smelling fine, the mildew smell was completely gone. How long it will last, I don't know.
I also read somewhere recently that we all use way too much detergent in our washers and dishwashers. And surprise, surprise, the post went on to say that too much detergent in your towels/clothes can leave a musty, mildewy smell in them.
Now when I do laundry, no matter what it is, I use about 1/4 of the amount of detergent called for, even though the HE uses so much less. In all, maybe 1-2 Tbsp, and everything comes out just as clean.
Also, try using a product from Clorox just for front loading washing machines. It's Clorox Washing Machine cleaner...it seemed to help with the overall smell. And I agree, I will never buy this particular machine again.
Aug 10, 2009 | LG WM2688HWM TROMM SteamWasher
What to use in my washer?
If your washer is rated for HE detergent, then you're supposed to use HE detergent. The reason being is that HE detergent is concentrated and specifically made for washing machines that use LESS water than conventional washers. Regular detergents are formulated for machines that use about 35 gallons of water for a full wash tub. If you use that same soap in a washer that only uses 5 to 7 gallons of water, you are in affect putting a higher concentration of soap in your new washer. Originally, manufacturers of HE machines stated that you could use regular detergents as long as you cut back on the amount. They later retracted that statement, because regular detergents were damaging the HE washers. You should review your warranty closely. Most newer models now have a disclaimer that states if you use the wrong detergent in your new washer, the warranty becomes null and void. I hope this answers any questions you may have.
Feb 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
298 people viewed this question
Top Washing Machines Experts
