Question about Lexmark All-in-One Printer with PictBridge
Having trouble getting my scanner to work.
I am attempting to scan some things on my X3350 All-In-One printer/scanner/fax. It is saying: Scan was not successful. It is telling me to make sure the "All In One" is turned on or to check the USB cable. I know that the USB cable is plugged in because I have been using the printer with no problem. We installed a new hard drive about a month ago and I'm wondering if I re-installed the printer incorrectly.
  • rawellersdic Mar 06, 2009
    Thank you so much for helping. I actually have Windows XP I think. Would this still apply to my issue? Where would I look to see which Windows I have? So I should un-install absolutely everything for the printer and then re-install it using one of the new driver downloads on lexmark.com?
    Thank you very much. I'll let you know if this works.
    Sergeant:
  • Lexmark Expert
  • 285 Answers
Are you using vista, if so make sure you have the latest drivers. Also, uninstall EVERYTHING for your printer and re install it from scratch from the new download from LEXMARK . com. The new HDD might have Something to do with it, as I have seen a similar case on a PC running vista with a HD crash.
Posted on Mar 06, 2009
  • Andrew Perrong Mar 06, 2009
    It verry well might. Go to run- WINVER. Yes.
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
Scanner does not scan MX890
you need to Reinstall the scan drivers, It will fix the issue
Regards,
Sean
Jan 22, 2013 | Canon PIXMA Office Equipment & Supplies
Can't detect printer when scanning MBP
Maybe the scan software is not installed yet. The Lexmark scan software can only be installed using the installation cd that came with the printer. It's not available for download online since it's a big file. If you don't have the cd or you lost it, I suggest you contact Lexmark Technical Support for assistance.
May 05, 2010 | Lexmark X3350 All-In-One InkJet Printer
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
HP 6310 won't scan from my new Dell laptop
You have to manually add scan options via settings>scan options>scan to>
that's within the HP solution center btw.
Apr 09, 2009 | HP OfficeJet 6310 All-in-One Printer...
I have a lexmark x3350 and the scanner wont scan
Alot of the X3350 all in ones have there scanners go bad if you still have a warranty for this printer then call Lexmark if not then you can go out and buy one for like $85.
Mar 26, 2009 | Lexmark X3350 All-In-One InkJet Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
Mar 07, 2009 | Lexmark X3350 All-In-One InkJet Printer
Fax sending problems
Does it also fail when scanning?
The light source may be shutting down partway through the scan.
Apr 28, 2008 | Lexmark X3350 All-In-One InkJet Printer
Scanner Failure: HP Officejet 6210
After hours of trying things.I found this and it worked. The scanner button doesn't work, but at least I can scan.
?id=microsoft.windows.resources.expandarrow To scan a picture using Windows Photo Gallery
    Before you begin, make sure that you've installed your scanner on the computer and that the scanner is turned on.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Windows Photo Gallery.
  2. Click File, and then click Import from Camera or Scanner.
  3. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
Jan 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark All-in-One Printer with PictBridge Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
