SOUND BUT NO PICTURE
I HAVE A 60PP9363H/17 PROJECTION TV. I HAVE SOUND AND NO PICTURE. I TRIED MY DVD PLAYER AND SAME PROBLEM. I WAS TOLD THAT IT IS INTERNAL AND I WOULD LIKE AN OPINION ON FIXING IT
  • MERLINS29 Mar 06, 2009
    YOU TOLD ME THAT IT WAS THE BACKLIGHT INVERTER ON MY 60PP9363H/17. I DON'T THINK IT HAS ONE. I LOOKED IN THE SERVICE SCHEMATIC AND DIDN'T FIND ANY . WHERE WOULD IT BE?
    MY TV IS A 60PP9363H/17 REAR PROJECTION TV . NO PICTURE JUST SOUND. CHASSIS # DPTV335
  • 6,784 Answers
Yes, this is internal and its located on the main board. this is a IC issue. mainly in the input section of this circuit board. You will have to disassemble to fix. i would also run a break point test on the deflection board. there may be a minor malfunction here.
Posted on Mar 06, 2009
    Scholar:
  • 165 Answers
Check the link below for possibilities and solution of this problem: http://www.repairfaq.org/sam/tvfaq.htm
thnks
  • 408 Answers
More than likely causes would be the bulbs or you Jungle IC Chips.  IC Chips normally require a professional to install and can cost in upwards of 100 bucks or more.  A end user can replace them themselves, however getting the part is another story.  I would take it to a professional and most will charge you 30 bucks to diagnose the exact problem.  There are many things that could cause it, to numerous to list on here without actually physically inspecting the tv.  But chances are, you are looking at an issue with the jungle IC Chip.
    Top Expert:
  • Televison & ... Master
  • 77,499 Answers
Is this a DLP projection TV? if so it is possible the hi intensity bulb is burned out.
    Genius:
  • 1,550 Answers
It tends to be problem of backlight inverter in your tv .
Check it .
  • SAM ANDERSON Mar 06, 2009
    You are facing this problem due to blasted ssb panel.
    You need to replace it .
    You can get one from the link below
    SSB panel for philips tv
    Sorry for previous post about backlight inverter .
No picture but have sound
no video output seems the video output part is faulty ask for tech to have a look
Jul 11, 2013 | RCA P61939 61" Rear Projection Television
I have a Philips 60".
Fluid has leaked out of one or more of your picture tubes ( 3 of them ) I suggest you call a service company asap because that fluid can destroy boards in a hurry.
Dec 10, 2010 | Philips 60PP9363 60" Rear Projection...
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Picture but no sound
It is most likely the SAP setting is in place. This will kill the sound
To reset the audio, go to the on-screen menu and select the setting for audio and make sure it is on stereo rather than SAP (second audio channel).
toggle the two and see which is compatible to ur Dvd player
thank you
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
is it nothing on the screen at all? if so your projector bulb blew. they usually cost a coupole hundred bucks
Mar 07, 2009 | Philips 60PP9363 60" Rear Projection...
Philips 60pp9363h/17
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Sep 09, 2008 | Philips 46PP9302 46" Rear Projection...
Phillips hd projection tv/ model 60pp9363h/17
thats a common problem with all projection tvs. You will need to replace both convergence Ics and 4 resistors. You will need two STK392-120 Convergence ICs and four 6.8 ohm 1watt resistors. You can get replacement parts at the following link and they provide free instalation instructions so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Philips 46PP9302 46" Rear Projection...
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
