Question about Cobra 29 LTD CB Radio
Have a clicking noise every couple seconds cobra 29
    Problem Solver:
Try a different ground and see if that works
Posted on Mar 08, 2009
How is it repaired error E-29?
Search Results
    Motorola Spectra FAIL and ERROR Codes
    www.repeater-builder.com/motorola/spectra/spectra-error-codes.html
    Dec 27, 2007 - Motorola Spectra FAIL and ERROR Codes. ... For example, a radioFAIL code may look like this: "FAIL 01/90", where the first two digits ("xx" in the ....FAIL 10/84, Trunking EEPROM blank, Troubleshoot Trunking Option, CB.
    [PDF]How to Use Your Cobra 29 LTD Classic - Cobra Electronics
    https://www.cobra.com/sites/.../manuals/29LTDCLA.pd...
    Cobra ElectronicsBefore installing the CB radio, .... Even though the Cobra 29 LTD Classic has an automatic noise ...... referring to the manual, you still need help, call Cobra ...
Jan 13, 2016 | Radio Communications
Cobra manuals 29 lx bt lcd
www.cbtricks.com click on vradio schematics,manuals , click on C then click on cobra ,then scan down to 29 lx bt . If you don't have any results do a serch engine for a service manual for it.
Jun 12, 2014 | Radio Communications
Cant adjust swr on cobra 29 with swing kit
make sure you have no noise in the background at all the be my guest. you may have to put a cloth over the mic speaker to keep the noise level down but you can do it.
Jan 28, 2014 | Cobra 29 LTD CB Radio
What is a voic box on a cobra 29 ltd? What is a good antt combo four a 29 ltd?
Cobra's LTD 29 model Citizen's Band radio features the full 40 channels allowed and a heavy-duty microphone. The radio provides 4 watts of AM radio frequency output with a switchable automatic noise limiter and noise blanker. Other features include Cobra's Delta-Tune function. Making a Cobra LTD 29 hear and receive better involves making changes to the radio's settings, including the settings specific to this brand.
M/F Turn the switch labeled "NB/ANL, ANL, OFF" to the "ANL" position and try the transmission again if noise is affecting reception. "ANL" is an automatic noise limiter function and reduces noise caused by the vehicle's electrical systems and electronics.
M/F Switch to "NB/ANL" to activate the noise blanker, which may also reduce noise if you continue to have problems. It's an RF noise filtration function and will help with ignition noise.
M/F Adjust the "RF Gain" knob by turning it clockwise to increase gain in weak signal areas if you have problems hearing radio traffic.
M/F Set the "Delta-Tune" function to capture a more listenable signal and get rid of adjacent channel noise. Rotate the knob labeled "Deltatune" to the center position for best tuning. Try micro-adjustments to the left or right as well.
M/F Turn the volume up if you still can't hear and as with any CB radio, adjust the squelch if the radio is noisy when there's no traffic. Turn the knob labeled "Squelch" all the way to the left to receive all signals, including noise and turn the control clockwise until the background noise stops. You will be able to hear the strongest transmissions without having to listen to weak signals and noise.
The service manual can be found here
Jan 23, 2013 | Lands Phones
How do i put variable power in a cobra 29
go to www.cbtricks.com click on radios,go to alphabet listing for c the cobra then click on the top where it says radio mods and info and there is what you want.
May 30, 2012 | Cobra 29 LTD CB Radio
How can i get my dx iv to recieve better by tunin
I am unaware of any dramatic improvement from tuning or germanium or schottky diode swaps in rigs that are the solutions in cobra 29 and galaxy radios.
You will see more promising result from a good quality antenna (wilson 2000 and coaxial cable 95% shielded. Then consider a preamp for improved RX however the nature of the AM band that cb radios operate on is overran with interference when you amplify the reception you also increase the noise and the filtering just is not there in these units.
The cobra 19 and uniden 510 such radios are very popular but cheaply made units you would be much happier with a Cobra 29 Chrome which is inexpensive but in my opinion has better reception than the cobra 29 ltd with the soundtracker gimmick.
Sep 06, 2011 | Cobra Radio Communications
I have a cobra 29 ltd chrome and it making a lot of static noise while driving or idling. it transmits and recieves fine though
Hi, my name is John. Welcome to FixYa. Try running your power strait from the battery, that will bypass a lot of your noise. RED (+) ground (-) . Thanks for choosing FixYa....John
Nov 30, 2010 | Cobra 29 LTD CB Radio
What exactly does the anl nb/anl button do on my cobra 29 wx nw st
ANL stands for "Automatic Noise Limiter" and NB stands for "Noise Blanker".
The ANL gets rid of a lot of interference noise caused by mechanical noise from motors and other electronic components in a car.
It also gets rid of noise from other sources of interference.
The NB is for extreme cases of noise, but can slightly lessen your receive sensitivity.
Basically both functions help decrease interference noise.
Nov 24, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
When i start my truck my cobra 29 ltd makes lots of noise
Sounds like an antenna problem, could be a ground issue
Nov 22, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
57 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
