Question about Homelite ZR10926 16 Chain Saw
INFO TO ADJUST CARBUERATOR ON HOMELITE Z3300 CHAINSAW. RUNS ON 2/3RD CHOKE AND REVS WAY UP, BUT CANNOT RUN SLOW. CLEANED FUEL, NEW FUEL FILTER, CLEANED MUFFLER SCREEN.
steve_lima
  • 181 Answers
SOURCE: old homelite chainsaw, wont pull fuel
most of the time there is a air leak in one of the two crank shaft seals.to get to them you need to pull off the flywheel and the clutch assy.look for wet areas. that will be where the seal is letting out the oil and air.If you keep putting starting fluid in the carburator you will burn the rings,the piston and the cylinder up
Posted on Jan 07, 2009
SOURCE: homelite runs wide open all the time
intake boot under carb is probably bad, mine did the same thing and this was the problem. about a 6 or 7 dollar fix
Posted on Apr 11, 2009
SOURCE: homelite z3300 chainsaw when it starts up the chain
i have the same problem with a 45cc 18 inch chain saw oh it is a homelite any help
Posted on Aug 30, 2009
dontbother10
  • 2220 Answers
SOURCE: On Homelite chainsaw model 410, where is the fuel
In the tank on the free end of the hose. HTH
Lou
Posted on Oct 06, 2009
dontbother10
  • 2220 Answers
SOURCE: 33cc 14 inch homelite chainsaw, wont rev up to
Morning William:
Acceleration is the "L" needle, try 1/8 turn CCW. No better 3/16 CW.
Please install a new filter on the fuel line, you will be beat to death with carburetor overhauls if you do not.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 27, 2010
Will fire,wont stay running.wants to be full choked,open choke,it dies
Jerry, First thing to get is a new plug gaped correctly and try. Could need carb. adjustment, fuel filter replaced, bad fuel line(cracked/pinched), Dirt/faulty diaphragm in carb. plugged spark arrester in muffler,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://answers.yahoo.com/question/index?qid=20090528073906AA0y882
Chainsaw will only run with choke
Stihl Chainsaw starts but won run
http://tekindoor.com/miscellaneous/stihl-chainsaw-troubleshooting
May 28, 2016 | Garden
What is the gas/oil mixture for a Homelite z3300 chainsaw
Most all chainsaws older and newer pretty much run on 50:1 ratio.
May 07, 2011 | Homelite Garden
Run on choke but willnot run when choke is off
U need to clean the carburator and empty old fuel out of tank 2 cycle gas gums up over time clogging ports in carburator also check fuel filter
Dec 11, 2010 | Homelite Garden
33cc 14 inch homelite chainsaw, wont rev up to high speed, will start and idle fine, but when you try to rev it up it just dies. I have changed the plug, cleaned the muffler, changed the fuel, rebuilt the...
Morning William:
Lou
Mar 27, 2010 | Homelite Garden
What is the gas/oil mixture for a Homelite Z3300 chainsaw
I cannot find a manual and it is not listed at Chain Saw Collectors Corner http://www.acresinternet.com/cscc.nsf. I did find IPLs and judging from them she is no youngster, based on that I am going to say the manual recommends 32:1 (1 gallon of premium fuel to 4 ounces of quality 2-cycle oil).
If properly adjusted up it will start easier, plugs and the exhaust will take much longer to carbon foul on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Lou
Mar 01, 2010 | Homelite Garden
I have a homelite super xlao chainsaw that will start up ok. But it will not rev up. I have replaced fuel line,filter and cleaned and rebuilt carborator and none of this has helped. Any advise would be...
You have done the normal things (good on you). Remove clean and reinstall the muffler and spark arrestor (it cannot inhale if it cannot exhale). Replace the plug because it could not hurt and is inexpensive. If no better try to tweak the carburetor settings. This is the best description I have found.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck. HTH
Lou
Feb 14, 2010 | Homelite Garden
Husqvarna 142e will not stay running. Going through the sequence of full/half choke it will start and run at high rpm when choked. Even after warmed up, it will die within a few seconds after dropping the...
If it is only running high at full choke - then it is not getting enough fuel.
You've cleaned out the whole thing - so it's not air that's the problem. It's running - so it's not a spark problem - it's a fuel problem.
If you have a fuel filter - change it out or clean it properly. If the fuel line is clear, then you need to adjust the running setting of the carb - there are usually 2 setting knobs -one for idle - one for running / mix.
You need it running richer till you get it going - then trim it back to stop it smoking and get a good rev.
Aug 28, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
Jun 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite hb 180 leaf blower
Changed all major gaskets: Cylinder to crankcase, case half, exhaust & carb. Now it runns right. The carb can be adjusted and the choke is full open when warmed up as it's supposed to be.
Gaskets ca be bought from Homelite directly at http://www.homelite.com/service_support/order_parts
Enter the model numbers & see the exploded views. Torque values are provided in the parts lists.
Nov 01, 2008 | Garden
Homelite ZR10926 16 Chain Saw Logo
899 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
