Question about Chrysler Pacifica Remote Start, Two Way with Start Confirmation 2004-2008
Mopar remote starter will start and turns off right away
The mopar remote starter in my 2005 jeep grand cherokee limited will start the vehicule and turns off right away(in less a second). Is there a way to programe it to start for a specific interval period of time?
  • 3 Answers
My Fiance' had the same problem as well as an issue with the key fob not working properly. We took it to the dealer and they replaced the ignition switch which fixed the problem.
Posted on Mar 10, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
What kind of power stirring fuild does a 2006 jeep grand cherokee grand laradoe 4 .7 v8 take ?
Mopar reccomends using mopar brand hydraulic fluid / power steering fluid. DO NOT USE ATF. This will damage the system. Honestly i have never not used regular power steering fluid and have never had a problem. If you are refilling the entire system, I would use the mopar brand. If you're just topping it off you will be fine using any power steering fluid.
Jan 27, 2015 | Jeep 2006 Grand Cherokee Laredo
What type fluid goes in transfer case of 96 grand cherokee
SELECT TRAC USES MOPAR PLUS 4 OR EQUIVALENT. THE QUADRA TRAC USES MOPAR TRANSFER CASE FLUID OR EQUIVALENT.
Aug 08, 2010 | 1996 Jeep Grand Cherokee
What other kinds of motors will fit into a 2000 Jeep Grand Cherokee V8? I heard some dodge motors would fit but I don't know what year or what make.
dodge is mopar what you have is mopar (jeep) 97 to 2003 i think will fit there tuff to come across i had hard time myself
Jul 09, 2010 | 2000 Jeep Grand Cherokee
What fluid goes in the transfer case of my 94 jeep grand cherokee larado?
on a select trac---mopar plus 4 atf or equivalent, quadra trac----mopar transfer case fluid or equivalent,
Jan 23, 2010 | 1994 Jeep Grand Cherokee
My 05 grand cherokee limited/hemi won't start, just clicks once.
95% of the time that means you need a starter, trying smacking it with a hammer while someone cranks the key
Oct 06, 2009 | 2005 Jeep Grand Cherokee
2005 Jeep Grand Cherokee Shifting Problems
Check the Trans fluid level with it running and at operating temperature. Jeep NAG1 transmissions are known to have the input electric seal leak trans fluid. Not an exspensive fix add Mopar ATF4 and then relace the guild seal.
Jul 19, 2009 | 2005 Jeep Grand Cherokee
T-Case drain and fill plugs
Visit someone dealer, and review this index:
- ZJ-Secc-0-Lubrication-and-Maintenance (Section 0, Page 0-18 and next)
- Jeep-1991-1993-MOPAR-Parts-Catalog
- Crown Catalog/ Transfer_case
Good luck!!!
Jul 09, 2009 | 1994 Jeep Grand Cherokee
What oil is used in a 1994 Jeep Grand Cherokee
Use Dexron® II or ATF Plus/Type 7176 automatic transmission fluid (or their superceding fluid type).
Jun 06, 2009 | 1994 Jeep Grand Cherokee
'06 Grand Cherokee LTD remote start question
why not read the manual for it.
be first.
there is one,, get it.
the rules are complex.
and getting more each year,.
there is 2 times fail rule
doors ajar
not in gear rule.
CEL can not be glowing, or it will not work.
there can be no errors, or it will fail.
and yes has get out of car rule, method
why put this on any car,, ? why risk having it fail
when with out it , car runs perfect.
why do that?
Mar 20, 2017 | 2006 Jeep Grand Cherokee
Chrysler Pacifica Remote Start, Two Way with Start Confirmation 2004-2008 Logo
1,333 people viewed this question
Top Mopar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Mopar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
