Question about GE 19TVR62 19 in. TV/VCR Combo
Remote doesn't recognize TV
I have a GE model TV Model #19TVR62.
I have a RCA remote Model #RCR311W.
I have gone through every mode in the manual to match the codes on this remote with my TV and none of them are working. What is the problem? Is there a way to reprogram the TV to recognize the remote without having a remote that works?
  • 1 more comment
  • ptstruska Mar 06, 2009
    No, I only have 1 TV.
  • Nicholas Lussier May 11, 2010
    While following the steps do the lights light up and go off as stated in the instructions? Also try resetting the TV by unplugging it then hold the power button for 10-20 secs then plug it back in, then try setting the remote again.
    Have you tried the remote on another TV to see if it is putting out a proper signal?
SOURCE: Can't get cable remote to operate GE 19TVR62
I found these remotes control VCR's only when programmed into the DVD button. It even says on page one of the manual that the DVD button is for DVD's, TV/VCR's, VCR's, etc. I got code 607 to control my GE VCR (using the DVD button). If that doesn't work, try 572 647 563 609 644 645 or 531.
Posted on Dec 23, 2007
  • 1694 Answers
SOURCE: GE universal remote for Ilo brand tv
www.remotecodelist.com ...........................................T.
Posted on Mar 22, 2008
IrishDruid
  • 2712 Answers
SOURCE: Ge remote control #24921
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
1Guru
  • 61 Answers
SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Posted on Dec 14, 2008
SOURCE: TV CODES
tengo un control remoto universal GH RC84912 nesecito los codigos l para un televisor philips me lo pueden enviar a mi correo danielesteban_30@hotmail.com de ante mano gracias
Posted on Jul 03, 2009
DROPPED MY REMOTE.NOT SET TO TV ANYMORE.TV IS A SHARP.I HAVE NO IDEA WHAT TO DO TO SET UP THE REMOTE FOR THE TELEVISION.MODEL #IS RCR311W. OTHER #2521P
Look in your manual for the codes and if not than look for the scan mode for autodetect. Buy another cheap remote ,no problem
Jan 12, 2011 | RCA Universal Remote Control
RCA Universal Remote Model #rcr311w
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Jan 11, 2009 | RCA Universal Remote Control
Need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Jul 19, 2008 | Universal Remote Control DIRECTV Universal...
Remote code
http://support.rcaaccessories.com/doc/Device_Documents/manuals/RCR311W_manual.pdf?deviceDocId=213&navtypeid=2&pagetypeid=9&prevPageIndex=5&selectedmodel=RCR311W&selectedFamily=generic&nvty=m
Above is a link to the instructions for your remote control
This "remotefinder" is a link to find the codes for the specific devices you want to program into your remote
Hope this helps!!!
Feb 28, 2008 | RCA Universal Remote Control
Dec 11, 2007 | GE 19TVR62 19 in. TV/VCR Combo
Rca remote controll model number rcr311w
I need the direction for programing my remote (model # rcr311w) for a toshiba tv model # 27A10. All help would be grearly appreciated. Thanks.
Nov 03, 2007 | RCA Televison & Video
GE 19TVR62 19 in. TV/VCR Combo Logo
151 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
