Question about Car Audio & Video
No power I have hooked all the lines up as instructed but the green light does not come on. The model is 211ZXi 4 Channel 240watts
  • 69 Answers
I would recomend useing a test light to be sure you have 12volts at the hot wire and the ign/remote wire, if so then check your ground, sounds like power is not makeing a good connection somewhere
Posted on Mar 08, 2009
Red light blinking green light steady on
THIS IS A NORMAL THING FOR UNIT TO DO
GREEN IS POWER APPLIED
AND RED IS HARDDRIVE RECORDING VIDEO DOWN
Mar 07, 2014 | Lorex LH118501C4 8 Channel 500 GB DVR with...
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Is it possible to hook up a powered subwoofer to this unit? It has a centre pre-out, but nothing labelled for a sub, and the manual is useless. This is a very nice old receiver, works perfectly, and I'm...
The only way to hook a powered subwoofer up to a VSXD903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
(To the guy [dunnbiker] that says there's no rear channels: You're wrong.) The VSX-D903S has 2 stereo (A/B) channels, dual center channel (place center speakers to the left and right, or above and below the screen), and two rear satellite channels. It is a 3-Ch Logic/Dolby Pro-Logic Surround equipped receiver, not a DolbyDigital/DTS multichannel x.1 surround unit.
Dec 19, 2010 | Pioneer VSX-D903S Receiver
Trying to hook up to digital converter box and cannot get the tv to see it? It won't let me in to set channels.
Check ur tv converter box a small button on the back of the converter box make sure it is not set to channel 4,make sure it set it to channel 3.Put ur tv on channel 3.Take the antena signal input put it in the converter box hole that call ANT.Take the wire that came with the converter box put the wire one side of it connected to the other hole into the converter that said OutPut.The other side of the wire should be connected to the hole in the tv said ANT hole.Now make sure ur tv converter box power a/c cord plug into the a/c power outlet and the power button is press on and have power to the converter box.The converter box now power LED light on indication should be on and it is green.Now the tv CRT screen picture should have a menu of the converter box funsctions.Just follow the on screen instructions and press the enter button on the remote and it will now auto scan for those free air Digital DTV channels.When the auto scan it reaches 100% is it done.Now u have done it.
Nov 12, 2010 | Curtis-Mathis Televison & Video
I hooked up my SMS (Model 1) to my TV according to the instructions but can't find the correct channel, despite having tried every single last one of them. The console itself seems to work as the "Power"...
Hi, get your hands on an AV cable which is available for that model at www.gameoz.com.au no more tuning in a channel just sellect video channel and away you go.... better picture quality too.
Sep 16, 2010 | Sega Master System Console
A 16/4 channel Mackie VLZ bought new 1997 hardly used. Some times a channel goes quiet, sometimes the fault moves to another channel, or while setting a channel input signal the knob seems to work till...
I suspect you MAY have a severe ground loop. The green light indicates channel crossover if nothing plugged in.
MAKE SURE ALL connected equipment is powered from the SAME receptacle. If you service amps from receptacles at one end of the room and this board from the other end, you are ASKING for trouble.
Read up on "common mode" as it pertains to balanced lines. Equipment can be at risk if grounds "bounce" as they often do.
When green light with no inout shows up, slide all faders down first. Then unplug input lines one at a time... turn off the amps and then unplug the output lines one at a time. See if one of these inout or output lines was causing the green light.
You should be using BALANCED lines to your amps... either XLR or TRS types at both ends.
May 17, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Tv will play for 30 minutes,it will loose channel,go to vertical lines for a few seconds then shut down with green blinking light
make sure that the cable is hooked up or the satellite isnt being stupid...make sure all the wires are correctly attached
Mar 07, 2010 | Televison & Video
My Lorex SV-01-RCV Wireless A/V instructions were lost in our move and I need help with the set up. Could you please help? I can not remember the correct connection.
You should have a 2-wire cable with Yellow, White and Red RCA plugs on each end.
The Yellow line is video out.
The White line is Left channel audio out.
The Red line is Right channel audio out.
Since your RCV only has two RCA jacks use the Yellow line for video and the White line for audio.
You should also have an "F-connector for co-axial cable.
If your TV set does NOT have audio and video jacks hook that to the co-ax antenna connector on the back of your TV set.
Set the RCV for either channel 3 or channel 4 and do the same with your TV set.
The RCV unit has four receive channels which must match up with the channel selected on the CAM or TX unit.
You can scan all four channels either by auto or manual.
If you only have one CAM or TX unit it probably doesn't matter which of the four you use unless you have a computer ROUTER which interferes with one of the four channels.
If so, select the 1, 2, 3, or 4 channel which has the least or no interference manually.
Bil Munsil
K1ATV HAM TV
Mesa AZ
Hams should be seen as well as heard.
Dec 30, 2009 | Home Security
Sharpe LCD TV...model LC-195K24U-K...can't get to change channels
what causes a line down the middle of my screen
Jun 08, 2008 | Televison & Video
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
