The picture on my TV is great. My problem is with the sound. When I turn on the TV, the picture comes on without the sound. In about 30 minutes, the sound comes on intermitenly. After a few more minutes, the sound comes on normally and stays on until I turn the TV off. If I turn it off while the sound is normal and then turn it right back on, the sound remains normal.
  • michaeltymch Mar 06, 2009
    What are the "ic connections on the main board"?
  • michaeltymch Mar 07, 2009
    My TV is Mitsubishi, Model CS-35403, approximately 14 years old. Tried unplugging the TV from the wall outlet for 30 hours. No luck, sound still doesn't come on fully until the picture is on for about 45 minutes.
    Any other suggestions? Thank you. MT
  • 19,396 Answers
That is usually a problem due to a broke solder joint (lose contact due to soldering broken) on the audio board inside the tv. The repair will cost about $150, but honestly, on a 15 years old crt , the repair is not really worth.
The TV is coming to the end of its service life, and this kind of troubles are normal on a 14 years tv set.
If you find a cheap local reapairer that do the job for less than 100 pounds it may still be worth repairing, but you risk an additional fault afterward, due to the age of the TV.
You can find replacements here.
Posted on Mar 07, 2009
    Sergeant:
    Novelist:
  • 277 Answers
Its the problem of ic number I323 OR I357 on main board which controls sound.that ic needs to be replaced to make the sound proper.as the ic is getting overheated and got internally weak.so not supporting the main board properly.replace the ic and it will work properly.
  • 10,594 Answers
As you said its 14 years old TV so I'm sure it has few weak capacitors, especially in power supply, deflection section and audio section.
Please replace capacitors those are leaky or their plastic jacket shrinked.
  • 408 Answers
IC connections, also knows as Jungle IC's is the chip that controls most of your video.
Posted on Mar 06, 2009
    Scholar:
  • 56 Answers
There is an "almost" connection inside the set. When components heat up, they expand and complete the connection. In your case, this takes about 30 minutes. Then when you turn the set off and back on, it is already warm, and contact is being made between the two pieces that are not connecting when the set is cold.
If you're comfortable with this, you can try to make sure certain all the pieces are connecting properly. Otherwise you will want to get your set to a qualified service center.
  • Damon Gray
    Damon Gray Mar 06, 2009
    What mradviser, Shadow and I are talking about is a bad solder, or perhaps an EEPROM that plugs into a socket but which is not making a good connection until the set warms up. Sometimes you can just gently (but firumly) press on the top of these chips and get them seated more firmly into the socket. If it is a bad solder, you need to be REAL comfortable with that sort of work in order to reheat and correct the badly soldered connection. Otherwise, you do need to take the set to a qualified repair shop.
  • 916 Answers
Unplug the set from the wall outlet overnight. Plug it back in, in the morning and test to see. This should reset the set back to factory defaults and should get rid of the sound problem as long as there is nothing internally wrong with the set.
    Scholar:
  • 165 Answers
This is the problem with the ic connections on main board.plse get it checked from a tech to solve the problem.
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
I have a ten year old 37" Sony XBR TV that works fine until you turn it off and then go to turn it back on. The picture does not come back, but sound does. The only way to solve this is leave it off...
most likely it needs repiars, (replacement of capacitors in the power-supply.)primary and secondary side.
Or loose conections (dry joints)
Apr 20, 2011 | Sony KV-27V22 TV
When I turn on the TV with the remote first thing in the morning I get sound but no picture. I leave the TV on with the sound on for 30 minutes and than begin to turn it off and on till I get a picture...
does the screen look lit at all? you may have an issue with the sustainer boards (Y and Z). without taking voltage readings at the power supply board it will be hard to tell. if you check, there may be bulging capasitors on the power supply board. if so, that will need to be replaced. you can contact hdrepair for a diagnosis and repair.
Nov 20, 2010 | Vizio JV50P 50 in. Plasma TV
Tv is on, after a few minutes it goes black and there is no sound. The indicator lamp is still green and stays solid the entire time. Without turning the TV off, in about a minute, you hear a small buzzing...
Someone else gave me the tip as I had the EXACT problem, but no buzzing. Unscrew the panel on the front bottom of the tv. Once that is off, there is another screw that opens a little panel. Unscrew the single screw with an allen wrench and pop out the bulb and casing. Mine was full of dust etc. Used an LCD cloth, but compressed air would do the same thing, put it back together and it works great!
Jun 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Picture fads to Blue after a 30 minutes the picture comes back with a blue tint.
yeah you need a tech to adjust the bias of the picture tube if you are lucky that fix it other wise the blue picture tube is bad
Apr 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
