Question about Singer 8280 Mechanical Sewing Machine
Singer 8280 timing procedure
I posted needle breaks- someone said if I emailed them they would send me the timing procedure-but they didnt. Can anyone help with providing the timing procedure for the singer 8280? Thanks in advance
Mimito7
  • 128 Answers
SOURCE: The needle on my Singer 132Q featherweight breaks
Sounds like it is out of time. I recommend you take it to your local repair center.
Posted on May 12, 2009
  • 240 Answers
SOURCE: breaks needle
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
Posted on Jun 11, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
  • 18 Answers
SOURCE: Demo for Singer 8280 sewing machine
Your machine can be found on the Singer web site here: http://new.singerco.com/products/detail/1337
There are links to instruction manuals and accessories on that page. You can also post in the Reviews and Question/Answers section on the bottom of the page to solicit feedback and help from Singer experts and other users.
Hope that helps!
Posted on Jul 22, 2010
Singer 8280 was sewing and all of a sudden the machine stopped working, the needle was in down position, would not release fabric, had to break needle to release.
Sounds like a piece of the needle is stuck in your bobbin case. Take it apart and brush it out. I mean remove your bobbin and the case, use a new paint brush if you do not have a brush with your sewing machine. Let me know if that made a difference, if not, we can try something else.
Jan 23, 2018 | Singer Sewing Machines
After replacing the needle in my singer 8280, the needle clamp is not holding the needle tight, the needle falls down even after tighening it..how do i make the needle get fixed?
It sounds like you have lost the tread guide. When you press the clamp as far up as it will go, there should be a slot in the post underneath the clamp visible. You may need to use a mirror to see it. The thread guide snaps into that slot and keeps the clamp from falling down. Take it to any repair shop. It will not be expensive to repair.
Nov 30, 2014 | Singer 8280 Mechanical Sewing Machine
What size needle for Merritt singer 3014
I could not find a Singer Merritt 3014 nor a Singer 8280. Do you have the serial number and/or model number? You can always try this site:
http://www.singerco.com/products
Jun 11, 2014 | Singer 8280 Mechanical Sewing Machine
Frequent thread breaking
Hai, Please check the thread tension and change the new thread and new needle. Otherwise put the some drops oil in the top and bobbin thread. Or go to mechanic shop.
Apr 16, 2014 | Singer 8280 Mechanical Sewing Machine
I would like to find a free prinatable version of the manual for the singer model 8280 sewing machine
Didnt I just send you the link?
here is link. select the middle one
http://www.singerco.com/accessories/manuals.html?man_model_no=8280
You will need free ADOBE READER to open and print
Hope it helps
Thanks
Please rate FIXYA
Apr 09, 2011 | Singer 8280 Mechanical Sewing Machine
Singer 8280 bent needle, now machine wont work
Depends what it would cost for service. Most standard service would cost at least $50-100. You can purchase a replacement machine for ~$100.
Amazon com Singer Sewing Machine Model 8280
Jan 01, 2018 | Singer 8280 Mechanical Sewing Machine
Singer 760 needle breaking
You need to retime the machine, if you email me I will attaqch timing instructions, drivewithken@blueyonder.co.uk
May 18, 2009 | Singer Sewing Machines
Breaks needle
Feb 14, 2009 | Singer 8280 Mechanical Sewing Machine
New singer 8280 needle hits overcasting foot and breaks
so, it sews for a while?  It sounds to me like the screw that holds the needle in place is loose.  As the needle moves up and down the screw loosens until that one fateful stitch, it comes out completely.  Try to tighten with a screw driver.
the other possibility is that it breaks if you are sewing over a bulky seam, like a flat fell.  as the presser foot "toes up" to go over the lump, the needle hits and there you are.
holler if that doesn't help.
Jan 18, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
126 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
