Question about Maytag Neptune MDE6700A Electric Dryer
3 prong to 4 prong cord
I just changed the 3 prong to the 4 prong cord in my stackable Kenmore laundry unit, but the the coats of the wires (the colored coats) recessed a little and now the actual wires are showing a little.
Also, the strain relief piece that came with the cord does not fit at all. Should I worry about both issues and call a professional, of am I ok?
Thank you!
  • 332 Answers
The bare wires are not a good thing when it comes to electric, you should either remove the plug and restrip the wires to fit or consult a pro to do this for you
Posted on May 29, 2009
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Can I change the 220 plug on the stackable unit from a 4 prong back to a three prong.
Yes you can. Green in the middle and red and black to the matching sides coming in from above the block where your connecting the cord
May 07, 2012 | Kenmore 98702 Stacked Washer/Dryer
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
The cord need to be changed from a 4 prong cord, 4 wire to a 3 prong cord, 3 wire 220V. which of the connections do i connect to?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
Sep 15, 2010 | Kenmore Dryers
I just moved and have a standard 3 prong outlet in my laundry room, the dryer has a 4 prong cord- what kind of replacement cord do I need to buy that will make the electricity of both the dryer and the...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-fareast-language: EN-US; mso-bidi-language: AR-SA" lang="EN">Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="" target="_blank"></a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span>
Aug 26, 2010 | Frigidaire Dryers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
I need to change the power cord on our duet dryer from a 4 prong to a 3 prong The 3 prong does not have a neutral wire does that matter?
I think you need to read the following link to make sure you aren't violating any electrical codes, first:
Yes, a 3-prong DOES have a NEUTRAL wire. That would be the WHITE terminal. A 3-prong does not have a separate ground. The NEUTRAL is usually grounded at the appliance casing by a jumper wire.
Read in the "Additional Notes" section on how to convert from a 4-prong to 3-prong. Also note that some of the newer appliances require a 4-prong plug in order to run correctly. I have a Kenmore HE3 model dryer that is currently using a 3-prong power cord. Since this model Kenmore is manufactured by Whirlpool, and is identical to the Duet, you should be okay with a 3-prong plug.
Aug 08, 2008 | Dryers
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag Neptune MDE6700A Electric Dryer Logo
249 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
