Question about Kenwood KAC-9152D Car Audio Amplifier
Hello i have a ken 9152d amp trying to get it to pull 2 alpine typ r 10" subs in sealed box made to alpine specs and they sound like **** i have doubled check wiring at 2 ohm and all is well there but you have to have deck at 3/4 vol to get much out of it amp at 50 on one setting and other setting is half way up now still no luck anyone have any ideas
  • 55 Answers
Just because the box is built for those subs doesn't mean it works well in your car. it's all about airspace if its in a sedan trunk try facing it towards the back of the car it will give it something to bounce off. If the box has one tiny pin hole it can make a BIG difference make sure it is sealed well. Make sure your positives and negatives are going to the right places on the speaker wire that can cause weak sounding subs. did you bridge the amp because that could be an issue also.
Posted on Mar 11, 2009
What box should i use for alpine swr-12d2
What size box does this sub need in a sealed box & a ported box. If you have room use a ported box that fits your subs. Probox & other brands may have the perfect box for them. I would tune the box to 40hz if you like loud tight bass.
Jan 24, 2013 | Alpine 2 Swr-12d2 Car Ausio 12" Dual 2-ohm...
I have a kenwood kac-9152d amplifer and it works just fine for about 10 minutes then just shuts off and subs dont work, about 30 seconds later my amp turns back on with the subs.
make sure it's well ventilated. If there's no air flow, then there is no way of cooling down and to protect itself it will shut off. Make sure the speakers are wired correctly as per amp specs. too many subs or subs connected improperly can draw too much current and shut the amp off, but you will notice this when you turn up the volume to a certain point and the amp shuts down.
Aug 30, 2011 | Kenwood KAC-9152D Car Audio Amplifier
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Hi there, my name is adam. I recently bought an alpine typs s 1043d sub (10'') and an alpine mono mrp-m500 amplifier. I was wondering a few things. 1) can u show me a wiring diagram or video or pictures as...
Hello mate,you can do one of two things, you can either google your amp model and download a pdf file of the manual which explains all of what you are asking, or you can email me at butcher960@btinternet.com and i will email you the pdf file, hope this helps you, colin.
Dec 28, 2009 | Car Audio & Video
Daisy Chaining 2 Mono Amps to 1 Sub?????
i beleive they have to be the same amps.an i think they have to be able to handle being strapped together.id look into getting new amps to run it elemental deisgns i know u can strap them together an controll them from the master amp.i dont think alpines handle 3ohms that good either.im going to check a few things an see if u can strap them two amps toghter.if u need more help email me bertman285@hotmail.com
Oct 15, 2009 | Alpine MRP-M500 Car Audio Amplifier
What to do
well i don't know your budget, but if that's not really and issue, right now at best buy, alpine type E, 10" subs, peak is 750w and rms is 250w, each is 129.99. Alpine type R, 10" subs, peak is 1500w and rms is 500w, each is 199.99. These are the best subs i found at best buy. You could sell your current subwoofers and purchase those, and you'd save space and still get the lows you want. Goodluck
Jun 27, 2009 | Jl Audio 12W7 Car Subwoofer
Amp makes noise. I am purchaseing a new amp
Hello termite440,
A mono amp will generally provide more power for subs. And for those Audiobahn's, you'll want something that will provide a minimum of 500-600 watts RMS to each, a least a 1000 watt amp. At the low end, something like the Alpine MRP-M1000 or the Orion HCCA-D2400 will provide 1000-1200 watts. I'd recommend the Alpine. For more power, and another $100, look at the Alpine M2000, or for another $250, the Rockford-Fosgate T1500-1bd.
Hope this helps.
Apr 28, 2009 | JVC KS-AX5500 Car Audio Amplifier
Have kenwood mono amp 4,2,1 ohm capabilitie. What is the best sub to run. The amp is 1600 watts, howmany ohms and 1 or 2 voice coils.
Hello pelikant75,
The best answer depends on your budget for the sub(s) and exactly what kind of sound you are looking to get. Your amps RMS output at 4 ohms is 200 watts and at 2 ohms, it's 400 watts. I could not find that it was 1 ohm stable.
If you are looking for the absolute best bang for your buck, I would highly recommend a pair of entry level MTX 10" subs, model 4501-04, currently priced by Crutchfield at $49.99. And if you buy a pair, they throw in a free Bass Slammer BS210S sealed enclosure. The MTX's power range is 112.5 to 225 watts each, right in there with your amps output. 2 of them in parallel give you a 2 ohm load, just right for your amps best power. And they sound great. You simply can't find a better deal for $100 bucks!
If you want a little better SQ, a pair of Rockford-Fosgate P1S410's should be considered. Again, going to Crutchfield, they currently have this one "BOGO" (buy one get one) for $99.99. You will have to provide your own box, though, no free one with these.
Finally, if you want the best SQ, and your budget allows, consider a set of Alpine SWR-1022D's for $179.99 each. These have dual 2 ohm voice coils, allowing you to series the coils and parallel the subs, resulting in a 2 ohm load to you amp just like the MTX's and RF's recommended above. You will probably want a somewhat larger enclosure for the Alpines as well as a fatter wallet. Your amp is right at the lower end for powering them, so they probably will not be as loud. But they will sound good.
One thing we haven't discussed is the box. The enclosure is just as important, perhaps even more important than the sub(s). More accurate bass is generally produced from a sealed enclosure. A ported enclosure will be louder, but at the expense of sound quality. And whether it's sealed or ported, the enclosure needs to have enough internal volume for the particular sub you are planning to use. A sealed box in the range of .75 to 1 cu/ft will be OK for any of the recommended subs. Add about 15-20% more volume for a ported box and keep in mind that the port needs to be specifically sized for the frequency for which it is tuned.
Hope this helps.
Apr 12, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Need to build a ported sub box for my alpine swr-1222d subs x 2
Try going to Alpine web site, I think they have box building program as well that you just input your sub models into and it gives you blueprints for various types of enclosures. I know Rockford has one and a comparative attachment to compare equipt specs. Or if you call Alpine headquarters you may be able to get info that way, I once sweet talked a rep @ a demo vehicle I met doing some car shows that turned me on to a senior rep @ Korbon Trading the owners of Rockford Fosgate and they gave me specs for a 5 stage band pass box for some competition subs that was more intricate and detailed than anyone before that could find me, Won me first place in spl. Matching your box specs to your subs is crucial and the best specs are often kept a secret for demo competition vehicles! So ask around with some competition guys or other top experts if your real serious about your boooom.
Mar 13, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
3 amps 2 subs sound system for car, need wiring help
As i read your problem i can recommend you that connecting each of the hifonics amp to each hifonics sub with the same specs by getting the specs in interfacing the two or you can simply look to the output of the amp and the input of the sub and find a suitable plug that fits to them.
In the case if you want to run each hamp to individually run each sub but sharing 3 farad capacitor: what i can suggest is that you connect in parallel one connecting wire of each input or ouput of the amp or sub. Its like connecting a connector from each of the input or output of the amp or sub to one leg of the capacitor, and connecting two wires to the other leg, one is being connected to the amp or sub and the other wire is connected to the other amp or sub.
In the case of putting a circuit breaker at the car battery: what i can suggest is that you find an appropriate circuit breaker that fits the specs of the car battery then connect it in series on the positive supply or read the specs of the circuit breaker before you connect it to the battery. Having a circuit breaker is like having a fuse but with special advantages in favor of the circuit breaker.
In the case of having power to the amps you can run one power wire to the amps by dividing the power wire into two, one connected to the amp and the other wire to the other amp. Then you can connect each amp and sub in series individually by connecting one wire b/w amp and sub. I hope i solved your problem
Feb 08, 2008 | Car Audio & Video
Kenwood KAC-9152D Car Audio Amplifier Logo
57 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
