Our Wireless is not secure; how can we make it secure/
    Scholar:
  • 165 Answers
Secure your wireless router or access point administration interface
Almost all routers and access points have an administrator password that's needed to log into the device and modify any configuration settings. Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all.  As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else. You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed. Without it, the only way to access the router or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
for more details or wireless security check the link below: http://www.practicallynetworked.com/support/wireless_secure.htm
thanks and rate the solution.
Posted on Mar 06, 2009
  • 13,433 Answers
What is your wireless router brand and model I will get you instructions.
  • Ekse Mar 06, 2009
    Here is a youtube video made by GetConnected. It explains about wireless security, I can give you step by step instructions ones I know the brand and model.
    Thank you.
    Enjoy the video
The wireless network security settings on laptop do not match settings on router?
Hello.
- This error occurs when the wireless security that you set on the wireless laptop does not match the wireless security on the router.
  • If the wireless router's security setting is WPA but on the laptop you used WEP for the wireless security, that's when a mismatch occurs.
- What you can do to resolve the problem is to delete the wireless profile you created on the laptop. After that, let the laptop search for wireless connection available, select the correct wireless settings and it should connect.
--For example the operating system of your computer is Vista, in order to remove the wireless profile you created and reconnect to the wireless router, do the following instructions:- Go to Start>Control Panel>Network and Internet> Network and Sharing Center- Click on Manage Wireless Networks on the left panel. Delete the wireless profile then Search for available wireless networks again. Type the correct wireless security settings on your laptop
-- If you would like to know what wireless security has been setup on the router, connect the laptop or use a desktop which is wired to the router then access the router setup page by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter. Enter admin for the router user name and your password (or the default, password).
--After logging in. In the main menu on the left, click on Wireless Settings, from there you can check the wireless security or you can setup wireless security from there if you haven't done so.
Hope this helps. Have a nice day. Don't forget to vote if you find this guide helpful. Thanks.
Nov 26, 2011 | NetGear WNR2000 Wireless Router
How to use dual band on router?
You can only use it in the 2.4 ghz mode or the 5 ghz mode:
1. Log in to the Router by going to http://www.routerlogin.net or http://www.routerlogin.com
and entering the default user name admin and default password password, or using whatever
LAN address and password you have set up.
2. Select Wireless Settings under Setup in the main menu to display the Wireless Settings
screen.
3. Select the region in which the wireless interface will operate.
4. Set up the 2.4 GHz wireless network:
a. Enter the SSID name. The default is NETGEAR.
b. Select the operating channel for the wireless mode. The default is Auto. When Auto is
selected, the router finds the best operating channel available.
If you notice interference from nearby devices, you can select a different channel.
Channels 1, 6, and 11 will not interfere with each other.
c. Leave the wireless mode set to the default setting of Up to 145Mbps for 2.4GHz.
5. Select security options for the 2.4GHz wireless network.
The wireless Security Options are set to None by default. NETGEAR strongly recommends
that you use wireless security. You can select a different Security Option and a different
passphrase for each wireless network. For the highest performance of the 2.4GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK as
your security option.
6. Set up the 5GHz wireless network:
a. Enter the SSID name. The default is NETGEAR-5G.
b. Select the operating channel for the wireless mode. The default channel is 36. If there is an
Auto option in the channel list and you select it, the router will find the best operating
channel available.
c. Leave the wireless mode set to the default setting of Up to 300Mbps for 5GHz.
7. Select security options for the 5 GHz wireless network.
passphrase for each wireless network. For the highest performance of the 5 GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK asyour security option.
8. Click Apply to save your changes.
please rate it and give a testimonial for my response
Thanks, Joe
Feb 02, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Where is my network security key
My friend,
You have to lo-gin into the router setup page .
1.Put this address (192.168.1.1) in the address bar and then you will see the router setup page.
2.Then this will ask you for the username and password.
3.Username is nothing so leave this blank and password is admin.
4.Then you will see the router setup page .
5.Click on the wireless Tab under the basic wireless settings you will see wireless security .
6.Click on the wireless security and you will see there your router wireless security key.
7.Always select Security Mode as WPA2 PERSONAL.
8.If you want to change the security key you can.
9.After changing the settings Click on the sav settings.
Regards:-
Amit Awasthi
Dec 09, 2010 | Linksys Wireless-G WRT54G Router
Wnr84b wireless settings security options only has 2 options
mostly u will be getting more security options oly with the high-end wireless devices. apart from the default security options, u can secure ur wireless network by many ways. turn off dhcp server in ur wireless router or access point. so it avoids unauthorized users from accessing the network. instead u may give a static private ip address for each and every wireless users for getting wireless access
Jul 22, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How do you switch the wireless internet on
The wireless light will glow only when you have a device connected to it and the security is related to wireless as well. Once you have any of your wireless devices associated with this router - the wireless light will come up and you may secure the wireless access by assiging security. Do get back to us if you need wireless access and security
Apr 23, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How to identify security type on my belkin wireless router relative to nintendo wii security type options
For nintendo wii , you can use the security WEP or WPA ( PSK ).
These 2 security types will works with WII. If you put WEP,then 10 digit number will be the security code.
To change the security on the wireless network, you will need to open the set up page of the router.
Once you change the security on the router, it is recommended that you will change the wireless network name SSID. after changing the wireless settings , you will need to connect to the new wireless network on all your wireless devices like laptop , wii.
Click Here for step by step instructions
Mar 05, 2010 | Belkin Computers & Internet
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
Dell TrueMobile 1150 won't connect to secured wireless acct.
well! some wireless adapter`s are not capable of connecting to higher security so that`s why for that it`s recommended you use WEP security instead of WPA.
Jul 01, 2009 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Security
Go to the router's web interface (192.168.1.1), in the wireless section go to Wireless Security. Enable WEP, you will create a WEP key for your wireless network, then that key will be asked to any wireless device that tries to use your wireless network.
Nov 29, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
