No signal shows on monitor
I have an Accer Aspire AST690-UP925A, problem is when i turn it on lights flash like it is booting up but not sure if it is because nothing shows on the monitor except when i turn the moniter on it shows ''no signal'' then turns off. Anyone know what causes this? Occasionally there is a beep along with it but not always. The monitor works just fine on other computers, but when i put other monitors on this comp. the same thing happens. Any ideas would be appreciated. Thanx
  • chrdcstl Apr 17, 2009
    The monitor works fine on other computers, but I get no response from the AST690 Aspire. Power is on (indicated by teh green light on hte front panel) but I hear no beeps, no display on the monitor, etc.
    Scholar:
  • 142 Answers
When a computer beeps on start up there is a crucial input output piece of hardware no working. If you have any experience with computers check to make sure everything is conected right. I inclued a link for support for your computer. Larry
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3390&LINKTEXT=Support%20Solutions
Posted on Mar 06, 2009
Accer aspire 5742 main board can't turn on
try it without battery installed to see if it's same
if not then battery needs to be fully charged or perhaps replaced
Jun 17, 2012 | Acer Aspire Computers & Internet
My accer 5115 laptop wont boot up it shows the green light when i plug in the power cord and wen I go to turn it on both lights light up and then go off. please help I have put in a new hard drive and it...
Use the OS CD/DVD to boot again and repair the OS. Next get the appropriate drivers compatible for vista from this site and install them on your laptop for it to function properly:
http://www.laptop-software.com/acer-software/acer-aspire-5315-notebook-driver-software/
Nov 11, 2010 | Acer Aspire 5315 Notebook
Can I install an intel E7400 in a Acer Aspire
check weather its is intel chip set board other wise i wont take
May 04, 2010 | Acer Computers & Internet
My computer is a acer ast690-up925a and only one beep when I turn
If one beep is coming while turning on this means the system is ok. If there is some issue with display please check cable for monitor once.
Thanks
Apr 07, 2010 | Acer Aspire T690 (AST690UP820A) PC...
When I turn on the aspire one note book it goes to a white screen and will flash once and go to white screen and stays there, owver all other lights on the panel flash normal, but will not boot up. this is...
If you're still under warranty, you can diagnose one possible problem easily enough. Blank white screen with the LED indicator lights running normally otherwise will almost always mean that the LCD panel is bad. If you don't have an external monitor available, find a friend with one and hook up the laptop to that monitor. Be sure to have the laptop power off when you attach the monitor cable. Press the power up button and then the Fn+F? (whatever F key has a little icon on iyt showing a monitor) combo to switch to an external monitor. If your laptop's Operating System shows up on the monitor, you know for certain it's jus your LCD panel that's bad and you can ask the manufacturer to replace it.
Dec 05, 2009 | Acer Aspire One PC Notebook
Acer Aspire T690 will not post. When powered on no video
You need to remove The Side-Panel. ( Power Lead out )
locate A small round Button Cell Battery.
As big as a 1p or a Cent Piece. ( Usually silver )
carefully prise the Battery Out For Between 10-15 Seconds, And Replace it. replace the power cable. switch on the computer, the bios has now been reset to it,s factory default settings.
if you are prompted to set date/time enter bios ( F2-del Or esc ) dependant On Bios request.
This Should cure your Problems.
Mike @ Compurepair.
Oct 16, 2009 | Acer Computers & Internet
ACCER aSPIRE 5920 NOT TURN ON.
is this a laptop? do you have an external monitor plugged in? do you have an external monitor to use? if it is a laptop then plug in an external monitor if it is not already plugged in, or if you already have one plugged in then unplug it.
May 26, 2009 | Acer Computers & Internet
I was out of town and got back to a problem, someone tried to install vista 64 over a 32 bit system(acer ast690) now cd drives will not work and all I get is GRUB page HOW CAN I GET MY SYSTEM...
When you boot up system.. did you get the black screen for entering Normal mode, safe mode??
If no, then try pressing F8 key, and see if you are able to bootup and get to desktop screen.
Post further to diagnose the problem
Apr 28, 2009 | Computers & Internet
Computer won't start up and has a constant tone.
If the noise is constant then it means the problem is either:
1: a Power supply issue
2: a motherboard issue
3: a keyboard problem
the latter of the three being the easiest to fix, try booting with your keyboard unplugged or even better if you have another keyboard try using it to see if that corrects the problem.
If the above does not work then you have a problem with 1 or 2, and in order to find out for certain you will need to test it, you can goto your local computer diagnostic store to see if they can check which it is.
and hope its not a problem with the motherboard.
Hope this helps, and Good Luck
Apr 13, 2009 | Computers & Internet
Acer Aspire AST690-UP925A
If you look at the back of you computer tower you should see 4 screws, one at each corner. Unscrew those one side at a time and that should allow you to examine the inside of your computer. Be careful when poking around because static electricity may short something out.
Aug 27, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
