Question about Toshiba Satellite A75-S206 Notebook
Toshiba a75 s-206 problems helppppppppppppppp
I have a toshiba a75 s-206 and it will boot from anyother disk that i put in it but when it first starts is has the toshiba screen and then that is it the lil white blinking line in the top left corner starts blinking and that is it. but no if i put in a windows xp cd to just redo the computer it says boot from cd press any key so i do so and then is says configuring system and then that goes away and thats is the screen stays black so i dont know. helpppppppppp
  • David Shaub May 11, 2010
    Mine did the same thing, and I did the same thing as you and got the same results. I tried it again and ate supper. When I was finished it was running. It's worth a try.
  • Nicholas Lussier May 11, 2010
    This is sounding like a bad harddrive, if you turn off the computer and lay your head on the palmrest and turn it back on can you hear the hard drive spinning, or do you hear any clicking noises?
  • Toshiba Master
  • 2,404 Answers
Sounds like a bad hard drive to me. Take out the hard drive completely from the laptop and boot up with the windows xp cd and it should go past the blinking cursor. At that point you know you'll need another hard drive.
Posted on Jun 17, 2009
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
My Toshiba hard disk is not functioning well
Hi,Dear Customer,
1> Please check you HDD cable connector.
2> Where from connect HDD cable in mother board, this port change and be care fully connect.
3> Check HDD bad sector. If you hard disk create a bad sector then not well run any hard disk.
4> Check jumper setting, first boot & sec Boot option. you hard disk where connect first boot & sec Boot option.
I think solve you problem.
Sep 12, 2012 | Toshiba Computers & Internet
Hi ... hey how do you run a xp disk i mean make it boot from my dvd drive i just switch the harddrive cause the other broke it a toshiba m2v trece
Put the disk in the cd/dvdrom start the computer and push F11 and pick the cdrom if it goes to windows boot screen start over
Apr 17, 2011 | Toshiba Tecra M2V-S310 Notebook
Unit failed to boot and observe the followng; - No start-up display - No CMOS boot-up display - Hard disk clicking sound and OS won't start
Turn the computer off.
Disconnect the AC power supply.
Remove the battery.
Remove the disk-drive.
Reconnect the AC power supply.
Turn the computer on.
Put any "data" disk into the CD-drive.
Does it display the CMOS boot-up display?
Can you hear the PC try to spin that "data" CD, i.e., trying to "boot" from it?
If it works "better" without the disk-drive attached, the disk-drive is the problem.
Jan 11, 2011 | Toshiba Satellite A105 Notebook
My toshiba L455D-S5976 will not boot up
now common is that a question?
dude stop wasting your time and mine ... please for god sake mentaion the detailed issue, things like,-
1. when did the problem begin?
2. any changes made since it was wrking fine,
3. is it not turning on at all or is it giving any error message ?
anyother info. that might help...
Thanks
Dec 27, 2010 | Toshiba Satellite L455DS5976 Notebook
I own a Toshibe Satellite L350D-215 running windows 7, when I power on the laptop it brings up the Toshiba welcome screen then loads a screen stating that there is or has been a problem and you have...
Sounds like you need to run the recovery disk
If your have the Recovery Disk put it in and boot from cd/dvd,
[Push "F12" at the Toshiba boot screen to access the Boot Menu]
you will loss all your info,,
to save your info [pic's] you will need to plug your hard drive into a desktop with sata.. and back up you info that way then run the disk
if you dont have the disk you will need to get a new windows 7 dvd or contact toshiba for a new Recovery Disk set,
Some times they put the Recovery on the hard drive but i think you need the disk with this one.
May 16, 2010 | Toshiba Satellite L305D-S5874 Laptop
Won\t boot up and dont have start up disks
please give more details about the problem, like error messages, color of ecreen, beeps, etc.!
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
Installing windows xp on toshiba protege 500
When you power up press F2 or "del" to enter in bios .
then set first boot option to as your dvd drive so then put winxp disk then it boot with it.
Jun 21, 2009 | Toshiba Portege M400-S5032X Tablet PC
Toshiba M45, no display, no boot, display button lights up about 3 seconds.
I have same problem with L30/L35 mainboard
did u find solution for your problem?
/o\
May 18, 2009 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite 1800 Disk Drive Problem
There's an issue with the way yout laptop is booting, either its set to the incorrect boot device or windows cant properly access the hard disk. Take it into a PC repair centre.
May 17, 2009 | Toshiba Satellite 1800-S253 Notebook
Toshiba Satellite A75-S206 Notebook Logo
207 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
