Question about Vehicle Parts & Accessories
Directstart cs-400 will not start vehicle
When button pushed lights light once then flash 4 times but will not start,
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 13 Answers
SOURCE: when i hit the start
I would sugest first that you check your users manual. You may have changed a setting with out knowing. if you cannot find your manual just go here http://www.directeddealers.com/manuals/og/python/G562P_07-05.pdf
it is in PDF format. If that is a no go your car may have a demobilizer and your bypass module may have become defctive or not installed properly. hope this helps.
Posted on Dec 04, 2008
dennymulford
  • 1055 Answers
SOURCE: 98 K1500 suburban, can not engage 4wd, HI or Lo runs otherwise
your doing it right but your accuater is bad 59.00 auto zone easy install
Posted on Feb 23, 2009
no85
  • 4 Answers
SOURCE: 3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Posted on Mar 20, 2009
SOURCE: the dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Posted on Apr 14, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
How do i program a black & decker model cm1050w to start coffee breding at a certain time?
I have one. It's easy. Push the program button. The little green light in the lower left corner will flash. The only tricky part is that you only have about 3 seconds to begin setting your time. After that the light stops flashing and you will be changing the regular time. While you are pushing the Hour or Minute buttons you have all the time you need to set your brew time, but once you stop you're back to the 3 second timer. Remember, if the light in the upper left side is on, the time is PM. To turn the timer on, push the Auto button and the little light in the lower left will come on and stay on. To turn it off, just push the Auto button again. Another caution, there is no "safety" for the Hour and Minute buttons. If you push either of those buttons while the lower left light is flashing you are changing the brew start time. If it is not flashing you are changing the real time. In other words, if you push either of those buttons at any time, you are always changing something. Happy brewing.
Sep 12, 2011 | Health & Beauty
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
On the remote I will push the unlock button, then the car's horn honks and unlocks the doors. It also honks when I want to lock it. I am only pushing the lock or unlock button once. I'm not in the...
You can disable the chirp confirmation by using the following procedure
1. Turn the ignition on
2. Turn the ignition off
3. Press the valet switch 5 times, wait for the Status Light to flash twice, the parking lights to flash twice and the horn to chirp twice.
4. Press the valet switch 4 times, the MARS unit will respond with 4 Status Light flashes and horn chirps
5. Press the transmitter START button, the MARS unit will respond with 3 Status Light flashes and horn chirps
6. Turn thr ignition on to exit program mode
May 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
How to program a crimestopper remote control model #chx433tx
To program this remote-
1) Open hood or ground GREY wire @ pin #7 on 12 pin connector coming from Crimestopper control module usually located under dash.
2) Turn key to on position.
3) Press red programming button coming from module 4 times, after a few seconds the parking lights on vehicle should flash 4 times.
4) Press button #1 pause, #2 pause, #3 pause, #4 pause on the remote you are programming, the lights should flash after ever button push. After all four codes (buttons) are learned, the unit will exit code learning mode. If not, turn off key and close hood. Hope this helps......BUZZ
Mar 07, 2011 | 4-Button Remote Start/Keyless Entry with...
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 12, 2010 | 5101 LE 1 Way Car Remote Starter System
How to program viper 5701 remote
Unlock doors
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
Dec 29, 2007 | Dishwashers
Vehicle Parts & Accessories Logo
357 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
