Question about Fargo Persona C30 Thermal Card Printer
Ribbon keeps ripping left side of ink cartridge?
Left side of ink cartridge keeps tearing.and id cards come out blank.
  • 526 Answers
First try a sensor calibration.
Posted on Dec 17, 2009
Evolis tears ribbon
You have to put darkness setting down on your driver.
2 chances: a) you have the headset with too much temperature due to darkness setting, or you are printing a particular color like metallic blue, gray or intense yellow that can make headset hotter.
b) When you say you have just a left side printed, i remembered customers that set the ribbon to 1/2 YMCKO, check it's not your case
Jan 21, 2013 | Evolis DUALYS 3 ID CARD PRINTER
Frequently, when printing a card, the ribbon gets stuck on top of the card and it goes under the exit roller, forcing the printer to stall. I then have to open the cover, remove the card, wind back the...
According to your problem, first check that you have put the card in the printer properly. These types of printers are very sensitive. It can make malfunction for a little wrong with card or also with bad quality card or printer.
Check the ribbon quality or change the ribbons which are not in good condition. Re prepare those ribbons in cartridge and then install the cartridge properly. Check the printer settings also and reboot it. Try this it will help you.
Jul 28, 2011 | Evolis Pebble 3 ID Card Printer Package...
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Paper keeps ripping on the side on normal one sided printing. Duoble sided printing paper just rips up and jams.
    sounds like some tron parper was stuck inside and has contributed to more paper tearing. First check for any paper jams, and check inside for and broken or damages items, causing paper to tear.
    Nov 27, 2009 | HP Officejet Pro K8600dn - - colour -...
    I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
    • Press the "Power" button to turn on your Lexmark
    • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
    • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
    • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
    Nov 19, 2009 | Office Equipment & Supplies
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Keep getting replace yellow ink cartridge error message
    Where did you get the error message on printer or computer?
    If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
    If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
    May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
    HP Deskjet 6940 not printing after replacing ink cartridge
    My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
    Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
    Fargo Persona C30 Thermal Card Printer Logo
    216 people viewed this question
    Top Fargo Office Equipment & Supplies Experts
    Safe-Card ID...
    Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
