Question about Black & Decker Simple Start Car to Car Battery Booster
Not charging I have the same product and it's a piece of ****. The only time I had to use it it didn't work as it was to be fully charged. I remarked that it discharged by itself in my glovebox. I tried to charge it, but when I plugged it into the wall and hit the charging button, it didn't worked. It's constantly beeping and no light are flashing, the charging light stays red and not flashing..... wow! an other great product from B&D!
  • 4 Answers
Here is what the B&D site says.
"If the unit starts to beep continuously, let it beep for about 1 minute, then turn the unit off and unplug the charger from the unit. Allow the unit to sit a full minute and then repeat the charging process.
If you still experience difficulties with the unit beeping after about ten attempts to charge, we recommend bringing the unit back to the retailer for an exchange, or taking the unit to the nearest factory-owned service center for assistance. "
They say the chip needs reset.
It didn't work for me though.
Posted on Sep 13, 2009
HBS-800 China made won't hold charge no more than 3 hours
Surly it didn't specify 79 hours of charge time did it? For 10 hours of operation the charge time should be around 20 hours or less depending on the charge controller device. I would hope it shuts the charging off once it senses the battery to be fully charged. Assuming all this is working as I've stated then I would conclude it is defective and seek to return/replace under warranty.
Nov 01, 2017 | Audio Players & Recorders
Blackberry 9720 suddenly went dead wont charge
Hi Michelle. I have the same phone and it happened to me a few times. On most phones the battery swells up when it reaches it's charging life end. In the 9720 the battery can still LOOK okay even though it might have reached its life-span. I eventually purchased a new battery, and wholaa, problem solved. A piece of additional advice is: Do not chat with you phone on the charger. Unplug the charger when battery is fully charged: We tend to charge the phone anytime and every time before we go to work or somewhere - you have to let the battery run flat on its own at least once a month, then start a fresh charge from fully flat to fully charged. This will prolong battery life. I a new battery does not solve the problem, have the charging pin checked out. Alternately if you know someone that has the same handset as you, ask them to stick your battery into their handset and visa versa. Hope this info help :)
Aug 26, 2014 | Blackberry 9720 Smartphone White, Factory...
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
Power switch not working
hello sir .. does your batteries are charged already??
if your batteries are fully charged and your camera didn`t turn on,
there`s a possibility that your camera has a problem. You can visit the store where you bought your camera and you can ask questions there why does your camera didn`t turn on whenever your batteries are ok .. :)
Feb 23, 2013 | Kodak EasyShare C142 Digital Camera
WORX 24V charger won't charge
I'm having the same problem. Worked great then didn't last as long. Now I'm stuck with this piece of crap useless piece of equipment. I'm back to spending too much time trimming with scissors since I can't afford a new battery non the less a new trimmer. Thanks a lot WORX! It doesn't Work! I'll never buy another of their product!
Aug 26, 2012 | Worx 24-volt Cordless Electric Lithium-ion...
I have an energizer rechargeable battery pack (not batteries) and recharge station for th wii, and when I let the pack fully charge and play with it, it dies in about ten minutes of play
with battery packs they usually die quickly that's just a con of pacs but if you didn't charge it the required amount of time the first charge you will just have to get a new pac or LOTS of batteries
Jul 31, 2012 | Nintendo Wii Console
Two red flashing led lights flashing. Constantly get the same problem fix and am tired of this problem had 4 controlers replaceded and several other things done almost $10,000 dollars done last year alone...
The 2 flashing red lights indicate a low battery. Did you have the batteries replaced? and did you have the charger checked? The charger could not be giving you a full charge or you didn't charge the batteries correctly. It takes about 9-10 charges to bring the batteries to 100% operating capacity. Always charge the batteries before using after installing new ones and then charge nightly when you sleep. When you get up in the morning the batteries should be fully charged and last all day. Never charge more than 12 hours and always store or put up fully charged Hope this helps and sorry that no one can seem to help you except spend your money needlessly
May 25, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
My samsung metro pcs phone wont hold a charge and I have a hard time getting the charger to work. No matter what charger I use I cant get it to work. If I get lucky the charger will work. What do I do?
there i no need troubling yourself further, the problem with your phone is the charging port, the charging port of your phone is bad that is why, your phone battery cannot hold charge.
Change the charging port of your phone and your phone will charge and hold charge.
Regards.
Apr 26, 2010 | Cell Phones
Charged for approx. 6 hours then wouldn't work
I copied this from the Philips website... this took me FOREVER to find! Their site isn't the easiest to find products on...
"Insert the small plug into the shaver and put the powerplug in the wall socket. When you charge the appliance for the first time or after a long period of disuse, let the shaver charge for at least 16 hours. Remove the powerplug from the socket and the small plug from the shaver as soon as the batteries have been fully charged. Ignore the charge indicator when you charge the batteries for the first time. The batteries are completely new and need to be charged longer than the time indicated by the charge indicator to ensure that the back-up capacity is fully charged as well."
I hope this helps. Please remember to rate my help! I would greatly appreciate it!
Apr 26, 2009 | Philips Philishave Cool Skin HQ6760/HQ...
It will not turn on after a full charge
Sounds like you have a bum unit.  Plantronics gives a 1 year warranty with every wireless product, I'd send it back.
Have you made sure that you're turning it on correctly?  You push the call answer button and hold it down for about 3 - 5 seconds before it turns on, until the blue light turns on.  Make sure that you don't hold it longer than that or it will go into pairing mode.
Apr 26, 2009 | Plantronics Discovery 925 Bluetooth...
Black & Decker Simple Start Car to Car Battery Booster  Logo
543 people viewed this question
Top Black & Decker Electrical Supplies Experts
micky dee
Craig Butler
Craig Butler
Are you a Black & Decker Electrical Supply Expert? Answer questions, earn points and help others
