Question about Refrigerators
My current gasket leaks air so I ordered a new one, but it came with no instructions as to how to remove the old one or how to install the new one.
    Scholar:
  • 67 Answers
You could hire a service repair person who specializes in this. I found websites about replacing gaskets but I don't know if it works for all refigerators gasket. The site was for replacing door gaskets. If you would have provided the make/model of your refigerator, it would have made it easier to find information on it. Regardless, here's a link to replacing a gasket.
http://www.rd.com/how-to-replace-a-refrigerator-door-gasket/article19314.html
Posted on Mar 06, 2009
    Scholar:
  • 165 Answers
Give the model number and details so we can provide you with some help
Where is the leak coming from on my 1995 honda accord lx
oil leaks around the filter generally mean that the oil filter is too tight and the gasket is damaged , filter installed on a dry gasket, -damaging the gasket, lip of the filter is faulty--manufacturing problem, the old gasket for the filter was not removed before fitting a new filter--- gasket squeezing out
remove the filter, best replace with a new filter, remove any old gasket stuck to the housing, put a thin film of oil on the new gasket and screw up to touch then 1/4 turn ( fitting instructions on the box or filter)
do not over tighten
Sep 25, 2016 | Honda Accord Cars & Trucks
Need to remove valve cover on 2000 Camry Toyota
For the four cylinder engine:
  1. Remove and label all electrical wiring, connectors and vacuum hoses necessary to gain removal clearance.
  2. Remove the spark plug wires. Disconnect the PCV hose.
  3. Remove the four nuts and grommets located on top of the cylinder head cover.
  1. Remove the cylinder head cover and the cover gasket from the cylinder head.
  2. Discard the gasket and replace with a new one.
To install:
  1. With a wire brush or gasket scraper, remove all the old gasket material from the cylinder head and the cylinder head cover gasket surfaces.
  2. When the cylinder head surfaces are free and clean, apply beads of sealant to the cylinder head in the locations shown in the accompanying illustrations.
  3. Install the new cylinder head gasket in the cover. Make sure that the gasket seats evenly.
  4. Place the cylinder head cover with the gasket onto the cylinder head.
  5. Install the four grommets and nuts. Uniformly tighten the nuts in several passes to 17 ft. lbs. (23 Nm).
  6. Connect the PCV hose. Connect all removed vacuum hoses, connectors and electrical wiring. Connect the negative battery cable.
  7. Start the engine and inspect for oil leaks.
  8. Repair any leaks as necessary.
For the V-6 (3.0L) engine:
  1. Drain and recycle the engine coolant.
  2. Disconnect the radiator inlet hose.
  3. Disconnect the throttle and accelerator cables.
  4. Remove the air cleaner cap assembly.
  5. Remove the V-bank cover. Use a hexagon wrench to loosen the nuts.
  6. Label and remove all emission control valve hoses. Disconnect any wiring interfering with the valve cover removal.
  7. Remove the air intake chamber. This will gain you access to the back valve cover.
  8. Disconnect the engine wire from the left hand side, No. 3 timing belt cover, rear side and right hand side. Most of the wiring is secured by nuts and or bolts to the body of the vehicle.
  9. Remove the ignition coils, make sure the place them in order on a table so not to mix them up.
  10. Remove the 8 bolts retaining the valve covers and gasket.
  11. Clean the mating area of the valve cover and cylinder heads well. If necessary, scrape any left gasket from either surface.
  12. Apply seal packing to the cylinder heads and place new gaskets into position.
  13. Attach the valve covers. Uniformly tighten the bolts in several passes to 69 inch lbs. (8 Nm).
  14. Install the spark plugs in their proper locations, then place the ignition coils into place and secure.
  15. Attach all engine wiring be sure to secure each harness properly.
  16. Install the air intake chamber. Refer to Fuel System .
  17. Attach all emission hoses and wiring.
  18. Attach the V-bank cover.
Apr 15, 2014 | 2000 Toyota Camry
Replacing jet
When you installed the new jet, did you install a new gasket on the wall fitting or use 100% RTF type silicone?
In order to seal a wall fitting that is cracked an leaking, the replacement must have either the gasket or silicone to seal the wall fitting against the wall of the tub or it will leak when filled with water.
Rod
U S Parts Center
Jan 03, 2014 | Jacuzzi Home
Oil leak from oil filter i thimk or its from very close to the filter
Your leak could be the result of a missing oil filter gasket or an improperly sealed oil filter gasket. Remove and inspect. either way, the fix should be easy.
Please remember to rate this solution.
The FixYa Team.
Feb 04, 2011 | 2000 Pontiac Grand Am GT
To replace thermoastic
You will need a few things to do this job. Lets start with the auto parts store- new thermostat(make sure it comes with the gasket), gasket sealant, coolant, (if your hose are 3 years or more)new hoses, hose clamps. now for the tools, scraper, ratchet, extension, and metric sockets, flat tip screw driver, and maybe pliers. got it, good, lets start. follow the top hose to the cap( or thermostat housing cover), on the air intake, and remove the hose. now on the cap, you will see 2 bolts(one on each side), remove the bolts and save the bolts. gently pry up the cap, and scrape it clean(to the metal), removing the old gasket, and gasket sealant. now remove the old thermostat, and clean that also(down to metal also) to remove the gasket and sealant. apply gasket sealant and install the new thermostat. place new gasket, and apply gasket sealant to the cap. replace the cap, and bolt back down(do not over tighten, the cap will break) reconnect the hose. allow 30 minutes to allow the sealant to set up. start the car and let it warm up. check for leaks. no leaks, great. allow to cool, and replace any coolant needed. Hope this helps
Jan 16, 2011 | 1994 Toyota Camry
Diagnostics test says idle air control underspeed error? how do i fix 1999 ford explorer
change the idle air control valve.
Idle Air Control (IAC) Valve OPERATION The Idle Air Control (IAC) valve controls the engine idle speed and dashpot functions. The valve is located on the side of the throttle body. This valve allows air, determined by the Powertrain Control Module (PCM) and controlled by a duty cycle signal, to bypass the throttle plate in order to maintain the proper idle speed. Fig. 1: Typical Idle Air Control (IAC) valve which is mounted to the throttle body - cutaway view shows air bypass direction 89684g16.gif
--- REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable. To remove the IAC valve, first disconnect the negative battery cable, then the IAC wire harness plug 89684p03.jpg
  2. Disengage the wiring harness connector from the IAC valve.
  3. Remove the two retaining screws, then remove the IAC valve and discard the old gasket. To install: When installing the valve, always discard the old gasket and install it using a new one 89684p06.jpg
  4. Clean the IAC valve mounting surface on the throttle body of old gasket material.
  5. Using a new gasket, position the IAC valve on the throttle body. Install and tighten the retaining screws to 71-106 inch lbs. (8-12 Nm).
  6. Attach the wiring harness connector to the IAC valve.
  7. Connect the negative battery cable.
Oct 15, 2010 | 1999 Ford Explorer
Changing a water pump on a 1981 ford f100 pick-up
Ford Pick-Ups/Bronco 1976-1986 Repair Guide Water Pump - REMOVAL & INSTALLATION
6-300 Engines
  1. Drain the cooling system.
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Disconnect the lower radiator hose from the water pump.
  2. Remove the drive belt, fan, fan spacer, fan shroud, if so equipped, and water pump pulley.
  3. Remove the alternator pivot arm from the pump.
  4. Disconnect the heater hose at the water pump.
  5. Remove the water pump.
  6. Before installing the old water pump, clean the gasket mounting surfaces on the pump and on the cylinder block. If a new water pump is being installed, remove the heater hose fitting from the old pump and install it on the new one. Coat the new gaskets with sealer on both sides and install the water pump in the reverse order of removal. Torque the mounting bolts to 14-18 ft. lbs.
V6-3.8L Engines
See Figures 1 and 2
Fig. 1: V6 water pump installation
Fig. 2: V6 water pump bolt torque sequence
  1. Remove the air cleaner.
  2. Remove the bolts securing the fan shroud to the radiator, if so equipped, and position the shroud over the fan.
  3. Disconnect the lower radiator hose, heater hose and by-pass hose at the water pump. Remove the drive belts, fan, fan spacer and pulley. Remove the fan shroud, if so equipped.
  4. Loosen the alternator pivot bolt and the bolt attaching the alternator adjusting arm to the water pump. Remove the power steering pump bracket from the water pump and position it out of the way.
  5. If necessary, remove the air conditioner compressor and bracket. The refrigerant lines should remain connected.
  6. Remove the bolts securing the water pump to the timing chain cover and remove the water pump.
  7. Thoroughly clean the mounting surfaces of all gasket material.
  8. Install the water pump in the reverse order of removal, using a new gasket. Torque the bolts to 15-22 ft. lbs. in the sequence shown.
8-360, 390
  1. Remove the bolts securing the fan shroud to the radiator, if so equipped, and position the shroud over the fan.
  2. Disconnect the lower radiator hose, heater hose and by-pass hose at the water pump. Remove the drive belts, fan, fan spacer and pulley. Remove the fan shroud, if so equipped.
  3. Loosen the alternator pivot bolt and the bolt attaching the alternator adjusting arm to the water pump. Remove the power steering pump bracket from the water pump and position it out of the way.
  4. If necessary, remove the air conditioner compressor and bracket. The refrigerant lines should remain connected.
  5. Remove the bolts securing the water pump to the timing chain cover and remove the water pump.
  6. Install the water pump in the reverse order of removal, using a new gasket. Torque the bolts to 20-25 ft. lbs.
8-351M, 400, 460
  1. Disconnect the battery ground.
  2. Drain the cooling system.
  2. Remove the fan assembly.
  3. Remove the fan shroud.
  4. Remove the accessory drive belts and water pump pulley.
  5. Remove the alternator and brackets.
  6. Remove the compressor and bracket and lay it aside. DO NOT disconnect the refrigerant lines!
  7. Remove the power steering pump and brackets. Lay it aside. DO NOT disconnect the fluid lines!
  8. Disconnect the heater hose and lower radiator hose from the pump.
  9. Remove the bolts securing the water pump to the engine and lift off the water pump.
  10. Clean all gasket mounting surfaces thoroughly.
To install:
  1. Install the water pump in the reverse order of removal, using a new gasket coated with sealer. Torque the bolts to 12-18 ft. lbs.
  2. Install all remaining parts in reverse order. Fill the cooling system, start the engine and check for leaks.
continue...
Mar 25, 2010 | 1981 Ford F 100
My oil pan is leaking around the corners. What do i do?
drain out hte old oil, Remove oil pan bolts, remove old oil pan gasket, install new gasket, install oil pan, tighten oil pan bolts to 17 ft. lbs. DO NOT OVER TIGHTEN as this will distort the gasket and cause another leak.
Jul 16, 2009 | 2003 Nissan Altima
Lower intake manifold gasket leaking 02 Olds Silhouette
This is basicly a very time consuming job rather than a physically hard one to complete. In order to replace the gasket you must remove the intake plenum,throttle body, and misc. vacuum hoses. The wiring harness connections must also be disconnected. Finally the intake manifold is exposed. The bolts holding the manifold to the block are removed exposing the leaking gasket. After removing the push rods and placing them in the correct order to be replaced the gasket and sealants can be removed. Finally replace everything in reverse order. Be sure to consult a GM manual for correct bolt torch specs. The correct specs for the manifold bolts usually come with the gasket. Make sure to change your oil a few times after this job in case any coolant entered the block. Also,change the thermostat and the oil seal on the distributor half shaft cap while you have everything off. Good Luck
Mar 17, 2009 | 2002 Oldsmobile Silhouette
Oil leak
If by head covers you mean valve covers this is an easy fix just install a new set of valve cover gaskets, as this is a fairly common problem ( valve cover gaskets ). Just unbolt the valve covers and remove them then scrape off the old gasket and install the new ones and bolt the covers back on. This is a pretty easy job and the gaskets are less than $ 25.00. If it is the oil pan gasket you will needto drain the oil and unbolt the oil pan and remove it then clean off the old gasket and install the new one.
Oct 07, 2008 | 1992 Chevrolet C1500
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
