Question about Miele S544 Artico Bagged Canister Vacuum
Artico miele vacuum cleaner power goes off and on while i vacuum.
  • 1 more comment
  • luise_lomb Mar 08, 2009
    yes, thats what it is. the power changing is
    related to the position of the cord.
    luise
  • luise_lomb Mar 09, 2009
    thanks, i learned something, but my problem isnt
    solved. i am going to replace the cord.
    thanks, LL
  • Rob Ristin May 11, 2010
    Does the power changing seem to be related to the position of the cord?
    -R
    Novelist:
  • 97 Answers
Ok, that's usually directly related to the cord reel's contacts separating. I actually just posted this fix as a response to another thread, but here it is: It is not generally necessary to replace the entire cord reel, although occasionally it is.
Here's the quick and easy DIY way to make your cord reel work again: you will need a #2 phillips head screwdriver, any flat head screwdriver, a pair of scissors, and a zip-tie.
First, remove the bag compartment lid by gently prying the hinge parts inward with the flathead screwdriver until you can lift it free. Remove bag and exhaust filter, and then remove the two screws holding the rear control panel on. Lift the front of the control panel upward until you hear a horrible unpleasant crunching noise. You didn't break it.
Lift that free, and remove all screws from the top of the main housing. (I believe there are 6 or so... but I can't remember off the top of my head.) The housing should then lift free.
You should now be able to see your cord reel. see if it wiggles back and forth along the central axle. If it does, you'll want to place the zip tie around the side of the axle which is away from the large round copper contacts which look almost like leaf springs. This will ensure that the contacts make electrical contact again. Cut off the excess zip-tie.
When putting the parts all back together, it is essentially a reverse of the disassembly, but be sure that you thread the cord through the hole in the back of the housing before you attempt to screw the housing down, or you will be very sad; both because you'll have to disassemble it again, and because you'll probably jack up your cord and have to replace the reel, which is what we're trying to avoid.
Test machine. If it works: party. If not, you will have to replace the cord reel.
For further clarification on the process, contact me.
Good luck,
-R
Posted on Mar 08, 2009
Tip
Miele vacuum cleaner suddenly stops
So this is a problem I identified in Miele's mid size ranged canister cleaners. Not only the S318...
If you go about cleaning on the highest power setting the engine will overheat after 5-10 minutes. It then will need around 20-30 minutes to cool down before you can use it again.
Tip: Don't run the machine on 100% power, instead turn the setting to around 80-90% and then you can enjoy good suction un-interrupted.
on Jan 28, 2010 | Miele S318 Bagged Canister Vacuum
Can anyone please help, my Miele vacuum cleaner will not switch on anymore.
www.mieleusa.com/Service
Most likely problem one of the wires leading to the switch. Ohm them out with a OHM function of a multimeter, while unpluuged , of course. .
Sep 14, 2014 | Miele Vacuums
My parents have a miele vacuum cleaner model s538. Do you know where I can obtain a repair manual for this vacuum cleaner. It is always on the "fritz". The vacuum has been taken for several...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Miele model by clicking the link below.
http://m.miele.ca/OperatingInstructions/en-CA/Vacuums/Previous%20models/Miele%20Vacuum%20Cleaner%20Manual%20S500-548_S600-648.pdf
You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 07, 2011 | Miele Leo S5381 Canister HEPA Vacuum...
I need a source for a replacement attachment compartment lid on a model #544 Artico. The hinge pivot have broken.
Hello. Any local vacuum repair shop can get that part for you or you can order it on the internet at this link
http://www.govacuum.com/miele-bag-chart.html
Feb 13, 2010 | Vacuums
Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
My Miele S544 Artico just quit working. I took it
Greetings from GoVacuum,
The repair for your model is identical, and no it doesn't cost $500, we sell cord reel for $103. I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel (hopefully from GoVacuum), You may purchase the S500 Series Cord Reel Here; Miele Cord Reel - s500 Series #5240304 .
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner2_bing.gif before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum2_bing.gif bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them.
If this repair guide was helpful to you, please click the four thumbs up icons in the top right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
GoVacuum.com
Jul 06, 2009 | Miele S544 Artico Bagged Canister Vacuum
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele S2511 Vacuum Cleaner Disassemble Question
My problem is with the power brush...I checked the belt and cleaned the rotating bar..still very low suction. The canister is still giving me plenty of power...thanks for any help
Sep 30, 2007 | Miele Vacuums
Miele S544 Artico Bagged Canister Vacuum Logo
503 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
