Question about Jensen's VM9312 Car DVD Player
Volume level whenever i turn the volume down before i turn it of and when i turn it back on the volume goes up to volume level 2.......in other words the volume goes up without me turning it up when i put it on
On this model it has a preset volume when it comes on. To change the preset volume press and hold the volume button on the reciever you will hear a beep or 2 and poof its done.
Posted on Mar 06, 2009
Samsung TV Version CZ04 volume reduces itself and whenever goes back to normal
Your volume goes down or up depending on the demand (number of viewers} viewing the channel at any given moment. That is mormal.
Nov 28, 2012 | Televison & Video
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
How do you turn the volume down .
1. Turn on the cube 2. Hold silver + yellow at the same time while the startup music plays 3. At the end of the music the voice will say "volume control, volume level ..." 4. Release the buttons 5. Tap either silver or yellow, listen to the voice and it will tell you the new level, "4", "3", "2", "1", etc. Yellow goes softer to a minimum of "1", Silver goes louder to a maximum of "4". 6. When you're done, just wait a few seconds and it will automatically ask you which game you want to play.
Dec 08, 2010 | Pfizer Electronic Rubiks Cube Rubik's...
Low volume on sony nwz-e453 mp3
Here is the combination for the servicemenu: Back 1,5seconds Hold ON Right Left Volume UP Volume Down Right Left Option Back Option Back
Now it should restart, then set Hold to Off. Under Audio you can change the settings.
Remember to be careful.
Nov 24, 2010 | Sony Audio Players & Recorders
Ipod Nano 3rd Generation volume problems
ITunes contains a volume leveling program that works with every recording in your library or you can select each one individually by going to the library, selecting get info with the right mouse button, select options, and change the volume with the control you see on the screen and press ok.
Aug 17, 2008 | Apple iPod nano 3rd Generation
Jensen volume
turn the volume level to what you want, when you still see the yellow level on the screen, press and hold the volume button till you hear two fast beeps, this will be the level you deck will start of at every time you turn it on
Jul 24, 2008 | Jensen VM9510 Car DVD Player
Amp volume problem
Sounds like you have a bad or dirty gain potentiometer. Try turning the gain up and down with the volume at a moderate level. If u hear static, it is possible the potentiometer is bad or dirty. Replace with one of the same value and see if that solves your problem.
Jul 15, 2008 | Rockwood Car Audio & Video
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
Jensen's VM9312 Car DVD Player Logo
771 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
