Question about Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster
I need a new pan - Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster
  • alnjimn Mar 13, 2009
    need poacher pan
  • hooter75 Apr 02, 2009
    The teflon on the included pan is coming off making poached egg removal virtually impossible.
  • 10,865 Answers
Purchasing a new pan plus shipping will cost u more than going to walmart and buying a new toaster.
Posted on Mar 06, 2009
How to change oil pan 1995 GMC vandura3500
I am guessing this is just like all vehicles and the oil pan is directly underneath the engine. You will need to buy a a new oil pan gasket and if you are replacing the pan, another pan. Take the bolts off the pan making sure that you allow the oil to drain out into a waste container. Once you get all the oil out, you can take the pan off. Scrape off any old gasket parts that might have stuck on the engine. Use some gasket glue and reattach the new gasket and pan. I would find out what level of torque you need for the bolts and use a torque gauge to tighten the bolts. Add oil and drive.
Oct 01, 2014 | Vehicle Parts & Accessories
Where do I check the transmisson fluid on a 2006 cobolt
The 2006 Cobalt does not have a dipstick check tube at all. It is normally a non-serviceable component unless there is a leak. When the pan is removed, for service you would normally add 6.9 US quarts to the transmission. I will paste the GM instructions for servicing the pan below.
2006 Chevrolet Cobalt
Automatic Transmission Fluid Filter and Seal Replacement
Tools Required:
• J 6125-1B Slide Hammer
• J 23129 Axle Boot Remover
Removal Procedure
1. Raise and support the vehicle.
2. Place the drain pan under the transaxle oil pan.
Notice: When removing the oil pan bolts, be careful not to damage the oil pan sealing surfaces. Such damage may result in oil leaks in this area.
3. Remove the oil pan bolts from only the front and the sides.
4. Loosen the rear oil pan bolts about 4 turns.
5. Lightly tap the oil pan with a rubber mallet or pry in order to allow the fluid to drain.
6. Inspect the fluid color.
7. Remove the remaining oil pan bolt
8. Remove the oil pan.
9. Remove the oil pan gasket.
10. Remove the oil filter. Use a long screwdriver in order to pry the oil filter neck out of the seal.
11. Check the oil filter seal for damage or wear.
12. As needed, remove the seal using the J 6125-1B and the J 23129 .
Installation Procedure
1. Install a new seal, as needed. Before installing, coat the new seal with a small amount of J 36850 or petroleum jelly.
2. Install a new filter into the case
3. Install the oil pan gasket. Use a new gasket if the sealing ribs are damaged.
4. Clean and dry the oil pan. Inspect the pan for damage and replace the pan if necessary.
5. Install the oil pan.
6. Clean and dry the oil pan. Inspect the pan for damage and replace the pan if necessary.
7. Install the oil pan.
8. Install the oil pan bolts.
Tighten
Tighten the bolts to 10 N·m (89 lb in).
9. Lower the vehicle.
10. Fill the transaxle to the proper level. Refer to Fluid Capacity Specifications .
11. Inspect the pan for leaks. Recheck the transmission fluid level. Refer to Transmission Fluid Checking .
Apr 27, 2014 | YouTube Videos
Oil Pan Rusted and needs replaced
ok not to hard to replace you need to go to auto store and buy a new one. it may or may not come with new gaskett they can tell you what size you need if it dosent come with a new one. also you will need to drain the oil before removing the old pan so make sure to buy new oil for that.. your basicly doing an oil change so you may as well get new oil filter too. then after you have everything... new pan, oil, oil filter, gaskett.. just get under take out oil plugg drain oil in catch can. remove the oil pan bolts you may have too tap the oil pan in different directions to get it to drop off. clean away old gaskett if you need to, and replace new gaskett and oil pan, lay new gaskett ontop of new oil pan and hold in place to get a couple bolts started then start and tighten all bolts useing a cross bolt tightining pattern to make sure the pan is in place{ tighten one bolt then do opposit bolt} change oil filter, and refill with oil.. if you need to see this done youtube is an excillent place to find videos on this.. i hope this helps... remember to let the car cool before doing this so get everything you need and start the next day before you drive.. nothing worse that getting hot oil down you arm while your laying on the ground...
Jul 24, 2011 | 1995 Ford Windstar
Won.t shift into grear, how do i replace the tansmission filter?
TO DO A TRANSMISSION FLUID CHANGE YOU NEED HAVE TRANSMISSION FLUID ON HAND YOU NEED TRANSMISSION FILTER AND GASKET.YOU NEED 3/8 WRENCH THE RATCHET TYPE WITH METRIC SOCKETS. YOU NEED JACK TO RAISE VECHICLE SUPPORT VECHICLE ON JACK STANDS.YOU NEED A DRAIN PAN. ONCE YOU GET VECHICLE OFF GROUND.PLACE DRAIN PAN UNDER TRANSMISSION OIL PAN REMOVE OIL PAN DRAIN BOLT.LET FLUID DRAIN OUT IN DRAIN PAN THEN SCREW DRAIN PLUG BACK IN PLACE DONT OVER TIGHTEN.REMOVE OIL PAN AND GASKET. BESURE TO HAVE PAPER TOWEL ON HAND.MAKE SURE TRANSMISSION OIL PAN GASKET SURFACE CLEAN BEFORE INSTALLING NEW PAN GASKET. ONCE TRANSMISSION OIL PAN REMOVED. REMOVE THE OLD TRANSMISSION FILTER INSTALL THE NEW FILTER.THEN WITH NEW GASKET ON OIL PAN IN PLACE.OIL PAN NEED TO BE CLEAN SO THE GASKET ADHESIVE WILL HOLD PAN GASKET IN PLACE WHILE INSTALLING PAN AND GASKET TO TRANSMISSION.INSTALL OIL PAN BOLTS INSTALL THEM CRISS CROSS TORQUE PAN BOLTS TO 7 TO 10 FT LBS. LOOK IN OWNERS MANUAL FOR TRANSMISSION FLUID CAPACITY.BUY 10 QUARTS .TO BE ON SAFE SIDE SO YOU WILL HAVE ENOUGH FLUID ON HAND. IF YOU DONT HAVE NO TRANSMISSION FLUID CAPACITY. ADD 7.5 QUARTS FLUID.WAIT FOR 2 MINUTES.CHECK TRANSMISSION FLUID LEVEL ON DIP STICK. SHOULD BE ON THE FULL MARK.CRANK VECHICLE UP.LET IDLE FEW MINUTES CHECK TRANSMISSION DIP FLUID LEVEL IF DROPPED ADD LITTLE MORE.WHILE ENGINE IDLING GETTING WARM UP. KEEP EYE ON FLUID LEVEL.WHEN FLUID LEVEL STOP DROPPING. APPLY BRAKES HOLD FOOT ON BRAKES SHIFT THROUGH ALL GEARS TWO TIMES. THEN CHECK FLUID LEVEL SHOULD BE ON FULL MARK.CHECK FOR LEAKS WHILE ENGINE RUNNING.
Nov 19, 2010 | 1996 Ford F250 Crew Cab
The pan shaft that goes up thur the pan has stop turning it bushing and other parts have stop working.Im needing a new complete pan.
Hi....If under warranty call for service. If not, then check out eBay or Amazon. You will need model # of your machine. Keep in mind that a new machine sells for around $50.00. Don't spend too much on a replacement pan when you can get a new Sunbeam. Hank
Jun 12, 2010 | Sunbeam 5891 Bread Maker
How to remove thesump automatic golf 2000
Sump meaning oil pan? Buy the white adhesive in a tube for the pan from the dealer. Once you remove the pan you'll need to clean out the old goo and apply the new one before you fasten the pan back to the engine.
If you're asking about auto trans pan, you'll need a new rubber seal, filter O-ring, VW oem auto trans fluid and a new filter. Then after all that work you'll need a scan tool to tell you fluid temp indicating the correct fluid level when it spills out at that temperature.
Feb 13, 2010 | 2000 Volkswagen Golf
Need to change the transmission filter
get your self the right tools, the filter, transmission fluid, gasket, gasket silicon, a good wide drain pan, clean rags, some cleaner to clean out the pan like brake parts cleaner. first find the transmission pan. once located undo the bolts around the pans flange or use the drain plug to drain all the fluid. if it doesnt have a drain plug then you have to take off the pan to drain it, messy! once the pan is off you should be able to see the filter and swap it out. clean out the pan, pan magnent, put your new gasket on and use some silicon, bolt it back on. fill the trans back with new fluid. this is straight forward approach. and dont mix the oil pan with the trans pan. the oil pan is under the motor( if that helps) let me know if you need any help or you dont understand something, thanks
Nov 07, 2009 | 1998 Honda Accord
My oil pan drain plug was stripped when i bought the car new and had an after market temp. plug. I would like to know how to take off the old oil pan and replace with a new one.
you need to purchase a chiltons repair manual. no overly difficult but the front cv drive shafts and starter may need to be removed. be sure to drain all oil out of pan before removing. use a new pan and gasket. before to check the tightness of the new pan's drain plug before adding oil.
Mar 22, 2009 | 2000 Mazda MPV
Oil pan for 1993 thunderbird
No you done have to drop any thing, you just need a new oil pan and gasket for it, loose all bolts around the oil pan and you should be able to remove it, remember remove all the broken off of the old gasket very well before you apply a new one on with grease or gasket cilicon stuff then new oil pan, good luck.
Sep 13, 2008 | 1993 Ford Thunderbird
Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster Logo
287 people viewed this question
Top Back to Basics Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Pierre Legault
Are you a Back to Basics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
