I cant figure out how to ADJ the convergence on my Panasonic PTL555U projector.. I can get to the ''Focus'' screen and I see the Crosshairs but I cant get them to move.. Any ideas???
These adjustments are internal to the machine, It is not a recommended user adjustment. Typically these are set at the factory under controlled conditions using a known signal source. Also, I'm not 100% sure about your model (I'll investigate further), but it may not be adjustable at all. How far out does the convergence appear to be? Can you see it under normal use conditions or only when using the test pattern?
Thanks,
Dan
Its not too far off, just sorta annoying...
