Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
The machine does not work
6.5kg smart drive excellence F& P washer. Gw609
The machine starts to fill with water and in about 10-15 seconds starts beebing with only the first green light of the long cycle and the the two lights of the spin cycle on. I can not switch the power off on the machine and have to pull the wall plug to switch off the power
Tna
  • 144 Answers
Ok this fault is telling me you have a faulty RPS(Rotor Positioning Sensor) in this machine. The RPS sensor is located in the motor Stator. To replace you need to remove the motor rotor then the motor Stator. you want to be careful with this part when fitting it as they can break.
Please rate my advice.
Cheers
Steve
Posted on Mar 25, 2009
Had the same problem with my GW 609 and fitted new RPS. Machine worked for 2 weeks o.k.. New problem with water not filling up correctly and machine stops, beeps and the three lights on. Swapped hot and cold hose and swapped connectors on Solenoid Valves. Machine is working fine. Cold Water Solenoid Valve was defect.
Posted on Jan 07, 2010
Washer keeps filling up and won't wash
Posted on Jun 06, 2010
I have long wash and short wash lights on permanant and machine will not spin
Posted on Mar 29, 2009
Fisher and paykel Smart Drive 9 excellence 7.5 washing machine wont fill at the start it just makes sounds like its trying then starts beeping?
the water soleniod has went bad pull out washer look to where water lines hook up to it turn of water to them then remove hoses unplug machine remove the soleniod valves make sure you write down the wiring order and hose placement on something get new valves replace rehook water line turn on water ect.
Aug 20, 2014 | Washing Machines
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Excellence smart drive fills up with water and then doesn't wash
Hi just read your posting. Now when the machine stops does it sound a beeping sound and a series of lights light up? If it does starting from left to right I need to know what light have come on in the row of 8 lights.Is it the 1st and 5th or 3rd and 7th etc.Please reply 4 further help.
Jun 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
When filling my F&Paykel washer the water is not a constant flow, it is filling in 'spurts', ie stop/start/stop/start etc...... I have tried cold, hot & warm water, all combinations of temp are...
You most likely have a smart water temp sensor on your machine. It makes sure you have the proper water temp to dissolve your detergent. Even when set to cold, it will add some hot water. It sounds like your machine is working properly. If you feel you are haveing a problem check the water temperatures in your owners manual and then check them with a thermomater in the washer. If they are not correct you may have a bad temperature sensor. Good Luck and I hope this helped. Mca0824@aol.com
Apr 30, 2008 | Washing Machines
Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
Jan 22, 2008 | Bosch Exxcel WFX 2467 Front Load Washer
F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
Dec 26, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
723 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
