Question about Avaya 8110M 1-Line Corded Phone
Assigning speed dials
How do I assign speed dials to a phone? I just need to create them.
  • Anonymous Mar 14, 2014
    assign speed dial
Leave the handset in the cradle and speakerphone off. press "program" button, (a constant beep will sound) press the speed dial number that you want to assign, then enter the phone number.
Posted on Mar 17, 2009
How do you set up speed dial on the LG OPTIMUS cell phone?
From the LG Optimus S Manual:
Assigning Direct Dialing Numbers
Speed dialing, as available in other feature phones, is
not available. However, you are able to directly save a
contact to your Home screen.
To set a contact as Direct dial:
1. Press (Home Key) >(Menu Key) > Add > Shortcuts > Direct dial.
2. Tap a contact from your Contact List. The contact
will be shown on the Home screen.
Direct Dial-
Simply tap the contact on the Home screen.
Jan 04, 2011 | LG Cell Phones
How do i set up speed dial on my KX-TG9391C
The speed dials are set in the contacts or the names directory. Open the directory and scroll down so that you see the options available to modify the names list. In this sub list you will find the speed dial. select this menu and open to see the locations 2-9. Since no 1 is assigned for voice mailbox you can assign the rest from 2 to 9 by select the destination and assigning with the selected name. Even for the no 1 voice mail box you can assign a name but must select it from the settings menu in the messages window, Now try to press and hold the set numbers to confirm that you speed dial works fine, Hope you try this out. Good day
Jul 29, 2010 | Panasonic Lands Phones
I have a Motorazr V3M. It keeps assigning speed
all cell phone do this, but you can force the speed dial to #2 thru #9...
(for example to find who is in speed dial position number 49 press 49# on cell)
May 30, 2010 | Motorola Mobility RAZR V3
Assigning keys
If you want to assign speed dial keys watch this clip
To assign other fuctions watch
Mar 11, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
I cant figure out how to set up speed dial?
Go to your phone call settings and activate speed dials feature.
Then come back to your phone in normal display mode,press and hold any desired digit e.g 2,3,4,5,6,7 on the key pad and follow the prompt for assigning of phone nos for speed dialing.
Sep 14, 2009 | Lands Phones
Panasonic KX-T7730- assigning speed dialing/one touch. I tried to press prog button and the one touch button..but it gives me an error message "not stored". How to solve this? I have 12 buttons to assign...
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Jun 04, 2009 | Panasonic KX-T7730 Corded Phone
For speed dial go to Main Menu >> settings >> initial setup >> Speed dial >> Phone Memory.
Than transfer numbers which you want to assign as speed dial in Phone memory.
Goto particular contact and edit the number and assign it as Speed dial.
May 20, 2009 | Motorola Mobility RAZR V3
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Dec 22, 2008 | Nokia 6085 Cellular Phone
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Avaya 8110M 1-Line Corded Phone Logo
220 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
