Question about Akai LCT3701AD 37 in. LCD Television
LCT3701AD will not come on
Faint blinking red light. Was working fine, turned off last evening and it will not come back on. Just a faint blinking red light. ANy ideas?
  • Anonymous Apr 12, 2009
  • mzinnocense May 24, 2009
    I have the same problem. It sounds like we are in need of a power supply main according to the other posts. Part number MLT386X PCB. I have the exact same tv. What a coincidence, or is it? Hope this helps, I'm trying to find one cheaper that $179...
I have the exact same problem. I believe we need Part # MLT386X PCB according to the other posts. It's around $179.
Posted on May 24, 2009
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
Wii has solid red light, won't turn on, faint ticking noise
if it was dropped check the bluetooth module , they can come unplugged and the wii will not function. Children love to put change in the wii which can short it out. Never bridge a fuse as it can cause unsafe conditions and potentially a fire hazard .
May 08, 2014 | Nintendo Wii Video Game Consoles & Games
My sony kp-53v35 keeps immediately shutting itself off
Older model---it should when you try to turn it on have the red light blink for several seconds (set is checking things inside) and if comes on and shuts off that light should blink a specific sequence of blinks----5 blinks and repeat it endlessly---
I have a stupid question: when it first failed did you hear a small pop or smell a faint odor of something burning?
Mar 22, 2012 | Sony KP-53V35 53" Rear Projection...
Screen is black and light is blinking. I tried
Can you see a faint image on the screen, if so your back light is failing. If you cant even see a faint image and is flickering then the inverter board is faulty and needs to be changed. You can search the internet by doing a google search for the make and model of your monitor and find spares, there should be some good videos on youtube on how to change the inverter.
Feb 09, 2010 | Computers & Internet
Hi i have a Protron, PLTV-3250 32" LCD. The tv was working fine last night and this morning it will not turn on? Do you know what could be wrong?
If you still have the red standby light on the front then the backlight is probably not turning on. Shine a flashlight on the screen and look for a faint image of the picture.
If therre is no red standby light on the front then your power supply is not providing 5 volt and you need to replace it. Part # is FSP194-0301.
Nov 22, 2009 | Protron PLTV3250 32 in. LCD Television
Sony wega kdf42we655 won't turn on...green light blinks, faint whirring sound, (fan?),then nothing...red blinking
Did you notice if the screen has been recently going darker if so the lamp has gone.You can check it by removing the lamp and looking at it you will see a grey smoked area or even the lamp mount broken inside the lamp.
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
Mar 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
Very faint picture- no sound
If the red lamp light is blinking the lamp is probably shot. The pricing of the lamp varies from $200 and up plus installation. Or you can buy the lamp and install yourself. See the owners manual on instructions to replace the lamp.
Nov 17, 2007 | Sony KDF-E55A20 55 in. LCD Television
Akai LCT3701AD 37 in. LCD Television Logo
276 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
