Question about Philips SA3025/37 Flash MP3 Player
My computer gives me an error message when i attach my MP3.
I recieve an error message the file or deirctory or currupted whenever i try to access the MP3 drive. It wont play music or videos at all. What can i do?
  • 8,596 Answers
Go to Philips website
Get the updated Philips Device Manager for your model (rather than the one that came with the CD)
Once you have installed the updated Philips Device Manager, open it, and click on the Update button - it will update your player's firmware, which should resolve your issue.
If you are, instead, getting a message that says "File System Error" - return your mp3 player to the store or call Philips and see if you can get an in-warranty replacement.
-Tha Mp3 Doctor
Posted on Mar 06, 2009
Laptop toshiba satellite Error says FILE INTEGRITY VOILATED,.... i AM UNABLE TO COPY FILES ITS GIVING ERROR
An error mesage makes the computer user aware of functionality possible have compromised the computer systems regular operationalities. For example, the computer expected to be manipolated as requested by the feature manual. A forceful shut down of the computer by pressing firmly on the shutdown button or pulling a plug may cause the computer to display an error message because of an abropt cut in processing requirements. Working with files for example may require to save in appropaiet area on the computer. A data saved at an alternate location that was disconnected liek a disk drive may display error whenever attempting to access an unavailable port area.
Jan 22, 2011 | Computers & Internet
Whenever i try to play a song on my phillips gogear vibe mp3 player it sais "file format not supported' and they are mp3 files.What gives?
"File format not supported" means that the song that you've downloaded into your MP3 player is NOT an .MP3 file format. For each MP3 player have their own supported file formats. You need to check the manual of your MP3 player to see what are the supported sound file formats (i.e. .mp3, .wma, .mp4). Then check the file format of the songs that are saved in your player.
If the songs are supported but you're still getting the error message, try to delete all the songs and then download the songs again and save it into your player. If the same problem occur, then it may need a firmware upgrade or reformat.
Thank you and good luck!
Oct 31, 2010 | Philips GOGEAR SA6045 MP3 Player
Outlook error message "the data in the envelope has been lost"
Try Thunderbird: http://www.mozilla.com/en-US/thunderbird/
Jun 10, 2009 | Microsoft Outlook 2002 for PC
File system error in (TRANSCEND mp3 T.sonic 630/1GB)
1.download the appropriate firmware from here 2.press and hold reset button for 2 seconds 3.run the firmware updater 4.press and hold "volume -" button while connecting to system. 5.the updater will detect the player and it will upgrade the firmware.
Mar 18, 2009 | Transcend T SONIC 630 MP3 Player
Error message
Whenever this happens on a GPX mp3 player it means you have to take it back. The hardrive is either corrupt or the files you might have downloaded on it are not compatible with the player. Try "mp3' and "wma" files and see if it works. I had this same problem so I took mine back for another mp3 player. Hopefully you still have your recipt so you can take yours back. Sorry if this wasant really helpful to you. I hope you can get a refund.
Mar 17, 2009 | GPX MW3836 MP3 Player
I cant get any songs on my mp3 player
Login to your computer as an administrator, and see if it still gives you the same message. If you still get the error message, make sure the hold/lock switch was not accidentally engaged. If the message still persists, right click the icon of the Sansa, and select Properties - see if a box labelled "Read-Only" has been checked - uncheck it.
-Tha Mp3 Doctor
Feb 11, 2009 | SanDisk Sansa Clip MP3 Player
Mp3 player is currupted
my flash slm01 mp3 player is currupted. When I click on the cd icon it states file system error
Aug 09, 2008 | Think Headtrip MP3 Player
DEVICE HAS'' READ ACCESS ERROR-CANNOT READ FROM HARD DISK''
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. If not you could try formatting it using a DOS prompt.
May 22, 2007 | Archos Gmini XS 100 MP3 Player
Philips SA3025/37 Flash MP3 Player Logo
57 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
