Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
My picture is to big for the screen
Even after changing the picture size on the remote the picture is way to big for the screen , chan I fix this?
  • 2 more comments
  • BHClark2000 Mar 06, 2009
    Yea, I tried that the picture is way to big and kinda to the left of my screen it is almost 2 times the size it should be.....
    yes it was recently move ( in the back of a pick up) bumpy road, the when we unloaded it an pluged it back in, it has multiple problems , the screen is to big,, the picture is concaved ( bowed in at top and bottom) halo effect on the colors....I took off the back and nothing is loose any where, I am very dicouraged and hate to just trash it cause it was so perfect before.
    K you guys are great, I have followed concaved adjustments and straighten out the concaved screen however the picture is still Huge any fix's for that?
  • Anonymous Mar 24, 2009
    I just spoke to a repair man who said that one of my kids may have pushed a button. He suggested unplugging the TV from the wall altogether and leaving it unplugged for at least 10 hours, then plug it back in and see if the tv reset itself. If it doesnt he will come out to look at it and I will tell you what he says. I am going to try it tonight.
  • 905 Answers
Have you tried resizing it with the button again ?
some channels just will not look as good in a zoom or aspect ratio when they are older recorded movies that are not digital recorded or in HD ( high definition )
Posted on Mar 06, 2009
  • 4 more comments
  • jason Mar 06, 2009
    have you tried to unplug the set from the wall for a few min. ?
    I just seen your other post , do you still have the concaved screen also ? because this is caused from the convergence IC's failing and or resistors on them .
    is this what happened to your tv set ?
    if you can solder , then resoldering of the pins on the convergence IC's and or look for the protection fuses (looks like a tan discap capacitor) for the convergence IC's . the convergence IC's will be on the big heat sink on the main board ,
    when it was moved a solder connection could have came undone and just needs to be soldered again , and if it did it may have also burnt a protection fuse as well
    if the pico fuses for the STK IC's are blown , then replacement of the IC's and checking of the resistor values on them will need to be done.
    the STK IC's are not exspensive but having a shop replace them is. $400 or more for a shop to replace the IC's AND pico fuses and or resistors if needed
    the STK IC's , pico fuses , resistors can be bought online or at a local electronic supply store
    you can cross reference you STK IC's here http://nte01.nteinc.com/nte/NTExRefSemiP...$$Search?OpenForm
    example of STK function http://www.nteinc.com/specs/7100to7199/p...
    hope my help has better served you and can be rewarded with a better rating , and if you need help in doing this repair , I will be happy to help
    you can search here for a supplier in your area here http://www.nteinc.com/NET_St_lst/Disty.h...
Why is the picture is to high or big and cuts off the heads of the people on my RCA HD52W59 rear projection HGTV
its setting the screen format . take the factory remote and by using the cursor left or right you can scan the size changes
May 23, 2014 | RCA HD52W56 52" Rear Projection HDTV
Picture has become too big for screen
Used ur tv original remote,look for a button like View Mode,Picture Size,Aspect Ratio,Zoom.Pushes one of these buttons to changes the picture sizes to fit ur tv screen.
Jun 05, 2011 | Toymax Skyworth SLTV-2663A 26 in. LCD TV
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
I have a samsung lcd 650 series tv and a dish network remote. I can use the remote to change channels and control power and volume to my TV. I cannot change the picture size and the picture on most...
We would be happy to help get that fixed. It sounds like you may be in the incorrect screen format. Press the * located below the number 7 on the DISH Network remote control. Cycle the formats to determine the screen format that fits best.
We hope that this fixes it for you. Thanks so much for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Department
Oct 27, 2010 | Samsung AH5900092W Remote Control
Trying to change tv format on my dynex 32 LCD
You are looking for a picture size, format or screen size button on the remote control to solve the issue. If it connected to a HD cable or satellite box then they also have format or picture size settings.
Apr 13, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a Samsung series 5 530 and the picture only recently is too big for the screen. also tried everything in the manual. Just started a few weeks ago.
The picture size may have been changed on the remote. Try the button that says pic size or something close to that. It must have been switched to a mode which zooms in the picture. That should fix it.
Jan 11, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Picture goes big and small
Look for button on remote labeled size,aspect ,format or zoom. You can change the picture size to your liking. Different channels are broadcast in diffrent formats.
Apr 26, 2009 | Televison & Video
Screen too wide
TRY THE ZOOM THAT IS WHY THE PICTURE IS TOO BIG FOR THE SCREEN......HOPE I WAS OF SOME HELP TO YOU...
Dec 16, 2008 | Samsung PS42P2S 42 in. Plasma Television
Model 51f59a hd widescreen aspect settings dont take and picture too big
I called Hitachi and the solution is in your cable remote not your tv remote. Your tv has a aspect menu as does your cable remote. Based on your cable provider you should have a settings or menu button to change the zoom or aspect of your screen. I had the same problem and have Comcast as cable and this worked for me.
Apr 25, 2008 | Hitachi 51F500 51" Rear Projection...
The picture is too big for my screen
press zoom on the remote control to get the normal size
Dec 24, 2007 | Toshiba 35A44 35" TV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
241 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
