Question about Samsung PS42P2S 42 in. Plasma Television
My antenna in is broken. can it be fixed. - Samsung PS42P2S 42 in. Plasma Television
    Problem Solver:
  • 10 Answers
Switch out the mainboard or tuner board depending on where the antenna is attached.
Posted on May 23, 2009
Tacoma(1997) power antenna mast with broken cord will not come out after the chrome nut is removed. Any suggestions? Antenna motor still works.
Power Antenna Mast Replacement 97 fjz-80 ' IH8MUD Forum > Forums > Toyota Tech Forums > 80-Series Tech
Oct 1, 2010 - I'm looking for a "how to" on replacing the OEM power mast on a 97 LC. ... The only tricky part is removing the funky nut that holds the mast in. .... what to do with the radio mast on my newly acquired 1997 Lexus LX450. ... if I have a broken cable, but the antenna itself comes right out of the top with no cable.
How to rebuild the power antenna - Cadillac Forums > ... > Cadillac Tech Tips - How to fix it
May 9, 2009 - 15 posts - ‎12 authors
Remove the liner to access the antenna and disconnect ANY of the two ... If notlocked the motor receives continuously power and will drain ... Broken nylon wire lifting/lowering the antenna mast 4. ... The motor shaft comes out from the plastic casing after you take out ... Do not lubricate the cable or the mast.
Saabnet.comt Broken Antenna FAQ - The Saab Network
If the cable broke in the antenna, you need to remove the antenna to remove the ... take a 17 mm wrench and remove the nut over the antenna where the mast comes out of the body. ... Hopefully the chrome sleeve will come with the old mast. ... Be careful not to drop them down too far. get the motor assembly on a bench ...Missing: tacoma ‎1997
How To Repair A Broken Car Antenna -EricTheCarGuy ...
? 20:53
May 24, 2013 - Uploaded by EricTheCarGuy
This video shows one way you can deal with a broken antenna. ... Find out why ... this video is that I did ...Missing: chrome
Jan 12, 2016 | 1997 Toyota Tacoma
Broken wireless antenna
It's advised that actually attempting a fix on a wireless antenna is uneconmical and it would prove cheaper to just purchase a new screw on antenna from your local ocmputer or electronics store.
Jun 02, 2013 | Computers & Internet
I have a Uniden 525 fixed mount 2-way VHF radio. It has power and picks up weather with the shakespeare antenna. However radio checks have failed and i don't receive anything either. The antenna's tip is...
Yes if the tip is broken, the antenna will receive, but not transmit properly. The make an antenna that has a 32" stainless steel antenna with a small metal "can". Can mount it anywhere.
Mar 28, 2011 | Uniden UM525 ES Series VHF Radio with...
How do you fix the radio "i can not hear anything
Make sure the antenna is up and not broken, some of these have the power antenna and some dont, if the antenna is up then you will need to check the cable that connects to back off the radio but i doubt thats the problem unless someone was working in that area of the dash, the most common problem is the antenna is broken or not up. good luck.
Feb 12, 2011 | 1994 Volvo 850
No gps signal on my tomtom one
the antenna is the cause if the gps is not having signal or reception.
Check the antenna is broken or well fixed. If not, you will have to replace the antenna.
Take care.
Jul 21, 2010 | Tomtom ONE XL GPS
How to find out if my power antanna works.. fix
If the antenna works you will hear the motor running with a broken mast. If not heard replace the antenna unit. If heard running get a repair kit for the antenna if Honda supplies this part
Jun 29, 2010 | 1995 Honda Accord
My antenna no longer seems to work, is it an easy fix?
The antenna connection on the Quest is very fragile and is easily broken internally. Fit an external antenna and this should fix your problem.
Jun 16, 2010 | Garmin Quest GPS Receiver
Power antena will not come up and the motors runs when i turn off the car.
the plastic in the unit is broke Must replace the unit very common
Mar 10, 2010 | 1993 Buick LeSabre
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
Apr 05, 2009 | Grundig YB 400PE AM/FM/SW Radio
Samsung PS42P2S 42 in. Plasma Television Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
