Question about Sanyo AVM-2506 TV
I was watching my tv (sanyo) with cable hooked to it. The cable all of a sudden went out. I tried hooking up the dvd player and the tv is no longer recognizing the cable box or dvd player. I don't know what to do. I took another tv from another room and hooked the same cable box and dvd player and viola there is a picture. But my tv just shows snow. But my tv is actually a Sanyo AVM-2503
  • 75 Answers
Sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Posted on Mar 06, 2009
What channel does it need to be on to play a dvd player I have the converter box
Ur tv have a video input holes R,Y,W.?Use the RCA cable R,Y,W to hook up to play the DVD player.Use the tv video 1 input to watch dvd movie.
May 27, 2010 | Sanyo DS25390 TV
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
I am trying to hook up my dvd player to my sanyo tv
I have red, blue and green cables when I hook them up to the back to the Sanjo TV I can't get the Audio to work. She has basic cable with no cable box just a converter box that give her reception. Should I put the blue and red cable on Pr and Pb and take the green cable and put it into the video out?
Nov 03, 2009 | Sanyo DS19310 19" TV
Have direct TV, need to hook up sanyo tv to a panasonic DVD.
leave direct tv cables where they are, and hook up dvd player directly to tv (do not hook up dvd player to direct tv box, it will not work)
Mar 15, 2009 | Sanyo Televison & Video
Cable hook up on tv is broke. trying to hook cable up to jvc dvd
Some times you can try tapeing it on (Black tape). Thats what i had to do one time.... It worked.
Jan 25, 2009 | Curtis-Mathis CM27101S TV
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Please help
You can find the manual here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b7a9e24543cb9cdef7c4e094fb734a9a&q=Sanyo+DWM-400
They will make you enter your email address if you want to download the manual.
I'm not sure you'll need the manual if you have a newer TV and want to hook this up the way most people do.
Just about all new televisons have a variety of video inputs. Typically you use one for your Cable box, one for your DVD (or VCR). When you wish to watch cable you "tell" your TV you want to view that input and when you want to watch the DVD player you tell the TV that's the input to use. Most Cable Box remotes are set up to control the TV so you can change the input without having to use the original TV remote. You can also, generally, change the TV input from the front panel of the TV set. If you give me the make/model of your TV I may be able to help you figure out how to switch inputs.
But back to the DVD. I downloaded the manual and this DVD can generate output in a few different formats. The easiest will probably be the jacks numbered 2 which is the Audio There are two them, one is RED, and one is WHITE, and jack number 4. This is the Video and will be YELLOW in color. I'll be the DVD player came with a cable set that has three connectors on each end. They will be colored YELLOW, RED, and WHITE.
You should simply need to plug one end of this cable set into the jacks mentioned above on the DVD player and then plug them into one of the inputs on your TV. Pay attention to which TV input you use because you'll need to select that input to watch the DVD.
If you have an older TV we will need to use a different method to hook up the DVD player.
Now for the editorial section. I'm not paid for this. I know it's a strange hobby, but I like helping when I can. If you have more questions please ask before you rate this solution. If anything I've offered here has been helpful I hope you'll rate this solution positively. About half of the solutions I've offered have never been rated. Thanks and good luck.
Jan 09, 2008 | Sanyo DWM400 DVD Player
Hooking DVD Player to TV
go to Wal Mart and buy a cable, its the cable with a red end an yellow end and a white end. Your TV does NOT support stereo sound, so you only need the white cable for sound, the yellow is for video.
Jun 10, 2007 | Symphonic WF803 DVD Player/VCR
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Televison & Video Logo
189 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
