Question about HP Compaq Presario V2000 Notebook
Computer not working, been a year now
Power surge, another computer in same power strip.
Now computer doesn't work, but the other one still does.
Cord still seems to generate power, but nothing happens when I press the power button.
I don't like to buy anything, but will if need to, PLEASE HELP
  • Chris Foegen Mar 06, 2009
    Sorry, I forgot to clarify that the other computer was a Dell vostro
  • 73 Answers
Test the cord, use it in place of the one on your other computer, if it works ok, then replace the power supply on the computer that will not start, however I warn you now, I have done computer repairs for a long time, and there is no telling what the "power surge" ate! you might replace power supply to find out the connector on the mother board was ate too. this is a trial and error thing or (process of elimination)
start with the power supply, if the cord is good, (and the cord will be fine).
Posted on Mar 06, 2009
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
Frequently power down
1. Power off the printer and computer and then disconnect the interface cable.
2. Power the computer back on.
3. Once the computer has booted, power the Brother machine back on.
- If the computer still reboots, restarts, shuts down, or enters hibernation mode, this problem is related to the power source for the Brother machine and computer. Continue to the next step.
4. If the Brother machine and computer are plugged into the same surge protector, uninterruptible power supply, or power backup device, power everything off.
5. Unplug the Brother machine power cord from the power device.
6. Plug the Brother machine power cord directly into a wall outlet or a different surge protector strip. You may need to use the reset button on the power device.
7. Power the Brother machine and computer back on.
Still having Problem Then follow Us For Brother Printer Support
Mar 23, 2014 | Brother MFC Office Equipment & Supplies
Computer wont turn on
Make sure the tower is getting power. There will be a green light on the back of the tower where the power cord goes. Make sure the cord is snug and that it is securely plugged in to your power source - I'm hoping it is a power surge strip and in which case, make sure the surge strip didn't get unplugged or turned off. If you have it plugged directly in to the wall then make sure that outlet has power by plugging something else in to it that you know works. After doing all of this, make check to see if there is a light on the back of your pc. If not, unplug the power from the back of the tower, wait 30 seconds at least, and then plug it back in. Hit the power button on the front just once, if it doesn't power up, press and hold the button in for a 2 seconds and release. If that doesn't work, your power supply may have gone bad. That happens from time to time. Good luck, hope this helps!
Jan 20, 2013 | Thermaltake Computers & Internet
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
If the computer will not power on:
  1. Make sure the power cord or AC adapter is plugged into the computer and into an electrical outlet that is live.
  2. If it is plugged into a power strip or surge protector make sure it is powered on.
  3. Try using a different electrical outlet.
  4. Check voltage setting on power source (AC Adapters are auto switching).
  5. Perform a power reset on the computer.
To perform a power reset:
  1. Unplug and remove the AC adapter and battery, or power cable from the computer.
  2. Press and hold the power button on the computer for about 30 seconds.
  3. Release the power button and plug the AC adapter and battery, or power cord back into the computer.
  4. Press the power button and see if the computer powers up.
  5. If that does not work, try a different AC adapter, battery, or power cable and repeat these steps.
If the problem persists the computer may need service. You may need to contact Acer support.
Nov 24, 2010 | Acer Aspire 5100 Notebook
I have a memory frame, modle mf-810. I received it 3-4 years ago, I think. It's worked wonderfully until about 2 months ago when we had a power surge. Is this a power cord problem? or is the frame...
a power surge may have fried it if you don't have a breaker switch on the plug that you plug your power supply into. The only way to really determine is to connect your photo frame into a second power supply if you have one to see if it works. I found out the hard way to always have a circuit breaker for my computer units after a power out fried my computer hard drive.
Dec 27, 2009 | Computers & Internet
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
My machine was working perfectly. Went to eat, and now it won't turn on at all.There is no light, and it seems to not have any power.
If the power cord is plugged into a power strip or surge protector, plug the sewing machine power cord directly into the wall outlet until this is resolved.
Check all power cord connections and push them in tightly.
If this works, then the power strip's breaker may have been tripped.
Please let us know if it works now.
Sep 21, 2009 | Bernina Artista 180
No Power
There is a whole lot the typical user can check but here is the list: -Disconnect the power plug from the power strip and plug directly into a tested wall socket. Sometimes the power strip sockets go bad. -Try another working power cord. -When you plug in the power cord do any of the monitor LEDs com on?
Jul 29, 2007 | HP vs19 (Silver) 19" LCD Monitor
HP Compaq Presario V2000 Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
