Question about Echo Inc. 44 CC, Carb Certified Backpack Blower
I need a carberator for an echo back pack blower
Echo back pack gas blower need carberator
  • Scot
    Scot May 11, 2010
    I need the Model and serial numbers to give you the correct information.
  • John McKinney May 11, 2010
    if you can get me all of the numbers off of your unit, I am sure I can hook you up with a great place to buy that carburater. thanks.
    Problem Solver:
  • 5 Answers
Hey I recently found out that Echo will not sell to public directly.
its on the web site .you can purchase through their authorized dealers
only. I purchased a carburator for $42.71.look out for price mark ups
from diffrent dealers.shop around.Good luck.
Posted on Mar 28, 2010
Echo blower wont start
ignition coil fixed my still backpack last fall
Apr 02, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
How do you fix the plastic gas line? It doesn't stay in the gas tank. When I prime the bulb the gas squirts out and when the echo blower is in use, gas ends up leaking on my leg.
The holes in these gas tank are made to fit available fuel lines tightly enough to prevent the problems you are having. If yours is leaking either someone put on too small a fuel line or made the hole larger so it would be easier to put the fuel line in the tank. The only fix is to get the next size larger fuel line or replace the tank. You can try to seal the line with RTV or silicone but he gas will degrade it and it will leak again plus you'll have a harder time the next time the line has to be replaced.
Jan 05, 2011 | Echo Back Pack Blower Rack Fits Stihl...
INSTALLED NEW CARBURETOR NOW WILL NOT START?
Assuming all gaskets and lines were installed properly, try priming it with a little gas directly into carb, or remove spark plug and put a little gas directly in cylinder and see if it picks it up. Sometimes for first start this is necessary.
Oct 05, 2010 | Echo Back Pack Blower Pipe Kit Pb4600...
We just bought an echo pb 250 leaf blower and can't start it at all. We bought one yesterday with the same problem and the people at home depot couldn't start it either. What are we doing wrong.
sounds like its not getting gas in the carberator yet. even though its new i would take off the air breather and pour a small amount of gas in airtake. this might get it started enough to prime the carberator and draw the gas on its own.
Jun 27, 2010 | Garden
Need oil/gas ratio for Echo back pack lblower - model PB-400E
Since every engine is different the manufacturer almost always has it printed in the gas cap. It should look like 50:1 or 50/1 (50 parts gas to 1 part oil).
Mar 31, 2010 | ECHO, Inc. PB-251C Handheld Blower
I have the Echo PB 265L leaf blower. When it runs it leaks fuel down my back. Seems to be coming out of a tub that is connected to the fuel button pump (which you push to prime when starting) I checked on...
I had the exact same problem with gas soaking my back and found out the yellow fuel discharge tube that comes out of the carberator was not inserted into the rubber gasket on top the fuel tank. The gasket has 3 holes in it for 3 tubes and the yellow tube fits into one of the holes. Hope this helps. It is a bit difficult to get the tube in the hole, but at least if you know what you are looking for you can get it to work
Oct 31, 2009 | Echo Garden
Can't get my Echo PB251 Blower to rev up at all, unit is 8 mo.s old was running fine now all of a sudden won't rev up, I have changed plug gas filter,cleaned all filters including spark arrestor changed...
guarantee exhaust is clogged maybe not muffler but exhaust port pull muffler off check screen and muffler then look into exhaust port usually rectangular port is closed down with carbon pull starter slowly to lower piston then scrape out carbon with screwdriver clean as good as possible then blow cylinder out make sure to get all pieces of carbon out reassemble should run fine
Jun 14, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo Inc. 44 CC, Carb Certified Backpack Blower Logo
345 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
