Question about Canon imageCLASS D320 Laser Printer
On my canon imageclass d 320 Copies have 7 evenly spaced horizontal black streaks on them.
    President:
  • Canon Master
  • 1,447 Answers
Please change copier cartridge.I am sure your problem solve
Posted on Sep 07, 2009
    Problem Solver:
  • 18 Answers
If what you are meaning is the streaks are not in the direction of the way the paper comes out - I would suspect it is on the drum or developer roller. Both items are part of the cartridge. If you roll the paper up to match one line over another and the end result is a tube about the sixe of a quarter - it is the drum. If it is the size of a dime - it is the developer roller.
Posted on May 29, 2009
Streaks on copies when original is fed through Imageclass MF 4694 top feeder; doesn't happen when on flatbed
There is dirt on the ADF glass. Normally to the left of the flat bed glass, there is a thin glass strip. Clean it with a damp cloth.
Aug 06, 2012 | Canon imageCLASS MF4690 Multifunction...
SEVERAL BLACK HORIZONTAL LINES ON COPIES
You need to locate the source of strikes.
1) remove toner crg., if it has black lines or dirts on drum replace drum.
2) check/clean copy glass
3) use flash light to check fixing section ( Left sideway of copier small doors ) if damadged replace fixing assy.
Jun 30, 2010 | Canon imageCLASS D320 Digital Copier
Why do I have a black line on my copies? I have the Canon imageClass D480 Multifunction copier
Pull out the toner crg., and if there are streaks on the drum, replace crg. If there is no streaks on the drum, clean the copy glasses.
May 22, 2010 | Canon imageCLASS D480 Black and White...
Large black horizontal stripe on copies from Canon ImageClass D760. Recently had ADF and rollers changed.
Sir,
If you place and orginal on the large glass and may a copy does the strip dissapear? If not it could be cleaning blade drum fuser unit? If the strip does leave then you have a problem with the docfeeder glass small long glass next to the big glass. Clean it!
Feb 26, 2010 | Canon Office Equipment & Supplies
I have a black solid streak on my Canon D320 copies
Change the OPC drum cleaning blade and clean used the vacuum cleaner the development station.
Dec 01, 2009 | Canon imageCLASS D320 Digital Copier
Streaky copies
It probably has several issues - optics dirty, and drum, and blade failing. I would also imagine that even the Solid "blacks" aren't as black as they could be, and that would be the developer. This machine is in the 17 year old range, and I wouldn't spend dime on it
Mar 29, 2009 | Ricoh Office Equipment & Supplies
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Mar 26, 2009 | Canon imageCLASS D320 Digital Copier
Black streaks
This is caused by a rotating part that is contaminated, most likely the drum that transfers the toner to paper.
A new drum or drum cartridge is probably needed.
There is a very remote chance that the high voltage that charges the drum is being modulated but I have seen this once in decades of service.
Aug 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Canon imageCLASS D320 Laser Printer Logo
157 people viewed this question
old marine
old marine
