Question about Whirlpool LER4634J Electric Dryer
How do I access the heater area. Dryer runs but no heat
Need help getting into heater area. LER 4634EQ2
I just took mine apart as it is taking longto dry. Can't figure the problem yet, but I had the heater unit out. The heater coils in mine are in a self contained unit which is easily removable through the back. There are a bunch of small socket type screws around the back that allow the cover to be removed, and the heater is held by a bracket at the top with just one screw. (threaded from behind)
Posted on Mar 11, 2009
Dryer working fine, but no heat, clothes not drying
not knowing what kind of dryer hard to help you out.. if it is a standard dryer most of time back panel can be removed and access gained to heater and thermostat ... you want to gain access to the heater area and unplug unit ... taking a multi meter check the heater by removing 2 power wires and checking contuinity to heater... should read through heater and if your meter has a tone on the ohms reading should beep at you.. check the limit/thermost the same way by removing wires to it and testing.. prior to doing all this make sure the vent pipe is clear all the way through and that you actually have correct voltage to unit.. even though unit comes on it will run off 120 volts ,but the heating element requires 220-245 volts to operate... test power at the back of dryer and make sure across the power cord you actually have full power...good luck to you
Jan 27, 2011 | Dryers
We have a Whirlpool LER 5636 Electric Clothes Dryer - the heating element gets too hot - starts to smell like it is going to burn. We have not used it since. Is it worth fixing? Thank you.
This can be a tricky fix. This could be the timer ? or High Limit Thermostat .First of all, I need you to do something...First, set the dryer to Air Fluff thats with no heat. Run it for 5 minutes see if the dryer is getting HOT. I know it should not but thats what I need to see . Then get back to me.
Dec 04, 2010 | Dryers
My LER 7648PQ0 whirlpool dryer doesn't heat but motor runs and programmer seems to run right. What is the problem ? I use an 220 V => 110 v transformer. How can I connect electrical wires at the back...
is your dryer 110v or 220v? If everything works except the heating element the element is bad or the one time fuse has popped it has two wires on it and one runs to the heating element or the hi temp switch on the heating element the fuse will be a small disc type when removed do not mistake the hi temp switch it is located on the element housing the one time fuse is ususally located on the dryer its self all of this is accessed on the back of the dryer under the back panel. good luck. (ground and common are the same in homes in mobile homes they are seperate and the dryers are 4 wire plugs L1 ,L2,neutral and ground).
Aug 08, 2010 | Dryers
WP dryer LER 4634EQ2, Was working fine one load
With dryer unplugged, check continuity between RE and Y on the timer. Be sure timer is pointed to the timed dry cycle. If open you will need to replace the timer.
Jan 15, 2010 | Dryers
No heat but dryer runs
First verify 220 volts of power to the dryer at the wire terminal where the cord hooks up. Look for a loose or burned connection here also. If power is OK,ohm the TCO and hi-limit thermostat on the heater canister. Ohm the heater. No ohm reading on any of these parts replace them.
Sep 29, 2009 | Dryers
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
Need help on getting into heater area to check out as to why no heat
access the heater assy fom removingthe back panel of uint, all thermostats and heaters can be check ed form behind, lookin for continuity thriough all thermos and heater
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won't heat yp
You are going to need a heater element OR a limit kit. A simple continuity check is all that is needed to confirm the failed part. Remove one wire from each component you check so you do not get a backfeed (false reading). Remember to unplug the machine.
If it turns out the clixons are all good and the heater is fine then the timer will probably be the culprit.
Dec 14, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
120 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
