Question about Refrigerators
Loud noise when stops ''running''.
I have a Kenmore 10+yrs old. Lately making a loud ''kachunk'' sound when stops ''running''. Otherwise cooling fine. What is it and can it be fixed?
  • 410 Answers
The noise your hearing  is a weak spring in the compressor. what happens is the compressor is a motor inside of a steel shell that spins at high rpm's when the unit shuts down and as the compressor starts to stop the weak spring is allowing the compressor motor to bang against the steel shell. around here we actually call these "Bangers". anyway the fix is obviously to replace the compressor. but considering the age of the unit you may want to move it to the garage and buy a new one for the kitchen.
Btw in my experience this does not interfere with normal operation of the unit it is just annoying. If I can be of further assistance please ask thanks Peyton
Posted on Mar 06, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' ...
? 4:32
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Inside the house I hear a loud squealing sound whenever the air conditioner comes on. It is still cooling just fine. It is a Rudd, about 10 yrs old.
alot of times that noise is coming from the orifice in the air handler it is the gas flowing through the screen could have pick up something in the lines
May 17, 2009 | Ruud UAKA030 Air Conditioner
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Feb 06, 2008 | Refrigerators
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
