Question about HP PSC 2210 All-In-One InkJet Printer
HP 2210 scanner self test problems
When i turn on the printer, the scanner jams when it goes through it's self test. After it jams it fails self test and won't let me proceed to printing functions. Is there a way to bypass the self test so that I can at least use the printer? Thanks
  • dispartyof6 Mar 06, 2009
    Thanks I will give that a shot
  • pb0aob Mar 18, 2009
    After power on the scanner fails, it keeps trying on the right side to realign itself but it tries and then scanner problem apears, it says turn of power and back on . Then it starts to triy again.
    Fotocel reader problem?
  • 29 Answers
If the glass of your scanner is too close to the scanner array it can jam. The cure for this problem is to open the case and put some narrow strips paper under the glass. If under Guarantee take it back.
Doubt if you can bypass the self test.
Posted on Mar 06, 2009
SCANNER FAILURE
The issue is with hardware of the printer.
Scan feature is most expensive and sensitive part of the printer.
I suggest you to contact HP support. If the printer is under warranty you may get a replacement printer or else they may give you a better option.
If not on warranty you may try this workaround:
  1. With unit off, press the 'Cancel' (pink button) and 'Color' (green button).
  2. This will start the printer in a diagnostic mode. Press '1' to run the diagnostics.
  3. Press 'Enter' or other keys as directed by the display prompts. When you don't know what to press, the 'Enter' key usually works. Some of the keys called for (for example 'Plus' and 'Minus') are not on every psc 2210 keyboard. They are mapped to one of the "directional" keys just above the numeric keypad area next to the 'Enter' key. Keep trying keys till one works.
  4. After all the diagnostics, the display will either go blank or display 'Initializing...' . Wait 10-20 seconds to make sure it isn't doing anything else then press the 'On' key.
The printer should start without the scanner error and the grinding/chattering noise.
Leave the printer on because the next power cycle brings the chattering noise back.
But, when it does, the procedure above seems to fix it every time.
PSC 2210 scanner failure HP Enterprise Business Community
Feb 18, 2014 | HP PSC 2210 All-In-One InkJet Printer
Hp 2210 all-in-one printer fax copier scanner-keeps saying remove door and remove paper jam and there is no paper jam. How do i clear this?
You can't I have the same printer and it is the stubbornest thing in the world. Just hit enter and keep printing.
Nov 18, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp 2210 all in one printer/scanner
after replacing the ink cartridge align the printer. Press alignment cartridge located in the printer properties. After printing the alignment get the paper and put it in the scanner. The computer reads it
May 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
Self-test issue with HP psc 2210 all-in-one
No fix, a new scanner will cost as much as a new machine IF you could find a new scanner assy
Feb 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Paper jams every time
does the same doc jam or all docs jam ?
on the first page or there after ?
Sounds like your printer may need a normal clean and service...
any decent printer repair company does this for a very reasonable fee...
Dec 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Problems on paper jam (just after the selftest)mode switches blinking
You may have to reset the printer. I believe these are the directions to follow:
Re-initialize the HP All-in-One Force the HP All-in-One to reinitialize by following the steps below:
  1. Turn the unit off by pressing the ON button.
  2. Disconnect the power cord.
  3. Wait five seconds, then reconnect the power cord.
  4. If necessary, turn the unit back on and try reading the photo card again.
  5. If the unit fails to read the card again, reset the All-in-One. Repeat Steps 1 – 4, but before plugging the unit back in, press and hold the # and 6 keys on the HP All-in-One numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the All-in-One reestablishes communication with the computer, reset the language and country/region.
Oct 25, 2007 | HP PSC 2210 All-In-One InkJet Printer
Initialize printer
I have had this problem on numerous times over the last five years. The way i have cleared it is to remove the plastic cover covering the buttons by gently lifting with a small screwdriver. Then tug at the buttons especially the scanner button to release it as it sometimes seems to gets caught. I also turn off the machine at this point from the power source for about 10-15 mins restarting after this time this generally clears the jam. I have also on the odd occassion uninstalled the software and reinstalled it, mind you it has taken a day on one occassion to clear the jam.
Oct 07, 2007 | HP PSC 2210 All-In-One InkJet Printer
Have problem with hp psc 2210 scanner.
pls take the machine to a repairs center,it is thier job!save your worries for other troubles
Apr 02, 2007 | HP PSC 2210 All-In-One InkJet Printer
Blank print out
This is laser scanner error message. The document is not being read from the data being sent. This could be a loose or damaged cable or bad scanner assembly. You can open it up and look for loose cables or connections to the board but otherwise if the scanner assembly is bad, it may require replacement. This should only be accomplished by a service professional as it is not a user serviceable problem.
Jan 29, 2007 | HP LaserJet 4350 Printer
HP PSC 2210 All-In-One InkJet Printer Logo
398 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
