Question about Texas Instruments TI-83 Plus Calculator
Ti-83 plus is frozen in the middle of a calculation.
Even if i turn it off for a period of time, when i turn it back on it is still stuck on that same calculation.
  • HxCJulie Mar 07, 2009
    I've taken my batteries out also and let it sit for a while..nothing helps. And me with my temper...I pushed a lot of buttons and now I'm frozen on a screen that says "EXEX EDIT NEW" Uhm..okay?
    Haha I just hit a bunch of buttons again...I ran my finger across every single one and it kicked it out of that problem. Woo! give it a try
This just happened to me. Running my fingers over helped because the problem was caused by a 'stuck' key. Sometimes it is clearly stuck to down but othertimes it is pretty hard to tell. Regardless when a key is pressed you can't press any of the others until it becomes unpressed.....so one thing to try is to hit the back of the calculator until the keys are all unstuck.
Posted on Jun 04, 2010
I get black "lines" going across the screen when i hit the graph button. It will graph also,but you can barely see the graph. Help pleae.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 04, 2013 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus "waiting ...please install message then "error message
Please Install Calculator Software Now error
This message means that the operating system has been corrupted. These steps will allow you to update the OS.
Unit to Unit
• Connect two TI-83 Plus units by means of the data cable (short black cable that was prepackaged with the TI-83 Plus)
• Make sure that at least one of the TI-83 Pluses contains the current Operating System
• Select [2nd] Link
• Select "Send OS" option from the Link menu
• Make sure that the other unit still reads "Waiting Please Install"
• The OS should be downloading.
From the Computer
• Make sure you have the latest version of the TI Connect™ Software
• Download the latest version of OS for the TI-83 Plus to the desktop of the PC.
• Connect the appropriate TI-GRAPH LINK™ cable between the PC and TI-83 Plus.
• Since the TI-83 Plus is currently off, the TI-83 Plus will automatically turn on when the TI-GRAPH LINK Cable is inserted.
• On your computer, choose Start, Programs, TI Tools, TI Connect, TI OS Downloader.
Dec 10, 2007 | Texas Instruments TI-83 Plus Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
My TI 83 Plus won't turn on, I adjusted the brightness, held DEL while reinserting batteries, replaced batteries but nothing changed
hi bckyshldn,
Did you remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. In the procedure that I give, you hold [DEL] and, re-insert 1 battery. I'm going to go ahead and, restate my instructions for a ti 83 Plus that won't turn on.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me anybody could make the same mistake. and of course the calculator will never come on if the batteries aren't in correctly.
The process below should reset your calculator.
Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds. Now, Pressing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. Is the screen showing any activity? If not continue the process.
  1. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
    message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. If calculator did not display the message try pressing and releasing the [2nd] key followed by pressing and releasing the up arrow for one second. goto step 2.
  2. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
    TI-83 family or TI-84 Plus family to reinstall the calculator operating system. If the calculator did not turn on connect the calculator to the computer and open Ti Connect. Next, open Device Explorer. Is the calculator asking to be installed? goto step 3.
  3. Steps to re-installing the operating system:
    ~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If the above process did not work. Try re-doing the procedure and, extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Now just in case this calculator wasn't posted correctly. Here's my instructions for a Ti 83 that won't turn on. This is not the same procedure that the Ti 83 Plus has.
  2. Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds. Now, Pressing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. Is the screen showing any activity? If not continue the process.
  3. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. And of course if the calculator does not turn on, I re-do the procedure and, increase the amount of time by 5 minutes to ten minutes that all the batteries are removed.
Jan 04, 2011 | Texas Instruments TI-83 Plus Calculator
Calculator freezing and shutting off
I see that you have an earlier version of the OS. You should update it to version 1.19 available at education.ti.com. Click the dowloads >> Apps and software menu.
The most likely reason for the RAM cleared is a depleted backup battery.
You might want to solve the problem and the update all at one go.
Check this article in the TI FAQ and Knowledge base for the procedure. The article contains an internal link to the OS Installation procedure.
Before you start on this journey, make sure the batteries (main and backup) are in a good state. Many OS installation failures happen because of quasi-depleted batteries.
Hope it helps.
Nov 03, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
Sceen keeps saying RAM cleared even when I didn't clear it.
There is a small round battery under a small rectangular cover just above the other triple A batteries. It has most likely gone flat. try replacing it, then see if it works properly.
May 12, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus will not let me view a table
I have just done what you said you had done, but I got a nice, correct table of values. You might have discoverd a secret command to clear memory.
Cheers.
Apr 14, 2009 | Texas Instruments TI-83 Plus Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
2,492 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
