Question about Whirlpool LSN1000LW Top Load Washer
What makes the Lid Switch Fuse Blow in a top loading Maytag?
Initially the waher would not pump out all the water after the spin cycle.After reading that one has to first see if the pump is pumping out all the water in the tub within 90 secs, I let the tub fill fully and it hardly let out an inch of water. Water was splashing over the sides of the top of tub and onto the sides of the outer tub. Then after 2 mins the whole unit went dead.
I opened up the control panel and saw a fuse back there that had blown. Not knowing the amperage of the fuse, I removed to brown wire to the water level switch and the 2 white wires with green stripes (coming from the check switch and the water valve). These were the wires connecting to the blown fuse. When I taped them together, the circuit breaker for the house blew.
I suspect the high water level and splashing around, made the check switch/water level switch or water valve short out and blew the fuse. The condition has not been recitifed so the fuse blew again.
I fixed the water stagnating in the tub. It was due to a sock between the inner and outer tubs.
But why did the tub lid fuse blow?
Why does it keep blowing?
Why does one have to replace the tub lid switch and the monitor switch?
Can someone explain this to me?
Lumpy816
  • 246 Answers
SOURCE: Kenmore Elite Model 27086603 Trapped clothing
Where the front panel and the top of the machine meet, there is a crack. When using a flashlight, you will see 4 items in this crack. 2 are green 2 are black. The black peices are support studs, ignore them. The green one's are clips that hold the top to the front. Using a putty knife (easier) or a small flat head screw driver (a bit more difficult) push one of the green clips towards the rear of the machine while lifting on the top. Only lift slightly (too far and it will bind on those support studs I told you about) Now press the clip on the other side and lift the top up. Now you should see your tub (from a new perspective) you will see a plastic ring around the top of the tub. Disconnect the green clamp on the hose towards the left rear using a pair of pliers or channel locks. The ring is held down with clips all of the way around the tub. By pressing down over each clip and pulling the lips slightly forward, you can remove the top ring. The rest is the easiest part. In the center of the basket, there is a small cap. Rremove this with a small flat head screwdriver. Remove the bolt that is underneath the cap. Now lift the whole basket out. If your small items get too far (ie, the pump), remove the back panel. On the left hand side you will see a small black hose towards the botom. this connects to the pump. Forign objects can ldge in here keeping it from draining also. If you disconnect the hoses, have something handy for all of the water to go into (large wet vac is usually the best). Drop the 3 #20 torx screws and the pump will come down and you can remove the obstructions.
Posted on Jun 19, 2008
  • 1028 Answers
SOURCE: No Spin Cycle
possible clutch is grease soaked
Posted on Jul 23, 2008
huuum
  • 750 Answers
SOURCE: whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Posted on Oct 14, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool LXR9445JQ having trouble with spin cycles.
Check the motor and make sure that the RPMs are high enough, Also check the tension on the belt
Posted on Feb 12, 2009
  • 686 Answers
SOURCE: LSR9434PQ3 Washer stops in cycle
weak capacitor. Bolts onto motor
Posted on Apr 06, 2009
Maytag MAV 8260 AWW Does not work at all. No water flow, no spin (even when filled with water from hose) Does it have an internal fuse? Where is it located? Is the large timer switch the brain of the...
Some model have fuse in top control panel, check lid switch, yes large button is the brains, it sometime can fail but usally only takes out 1 of the cycles.
Nov 02, 2013 | Maytag MAV7600 Top Load Washer
KEEPS BLOWING FUSE WHEN I CLOSE THE LID
its in the lid switch safety assembly,there is a glass cartridge fuse on this board and if the lid switch sticks it will blow this fuse to power down the machine to protect the uses from it spinning with the lid open this board is available from most maytag dealers or appliance parts dealers
Dec 11, 2012 | Maytag LAT2600A Top Load Washer
Maytag Centennial washer mvwc400xw0 washer won't fill
It could be the door lock, the water valve, screens on hoses and valve, or the drain pump
Nov 05, 2017 | Maytag MVWC400XW - CentennialR...
Just curious, if my washer won't fill but the spin cycle still works, does that rule out the lid switch as the problem?
No if doesnt rule out the lid switch yet in fact that very likely is the problem,the lid switch asm. is wired through a fuse that if lid switch is bad the fuse will blow and in addation to the fuse being wired to the lid switch,it too is wired to the water inlet valve and will not fill if the fuse on lid switch asm. is blown
I know this by replacing more lid switch/fuse assamblies in 30 year appliance repair career that i can remember. I dare say (by assumption) that the tech that came to diagnose your washer gave you the exact correct diagnosis
Jul 28, 2011 | Maytag LSE7806A Top Load Stacked...
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Kenmoore washer , model 2262210 serial cl4434210, type111 . will not spin and does not drain . what are the possible problems . please help . thanks . T.W.N. at tednicol@msn.com
if this is a traditional top load washer, then your lid switch might be bad. Usually when this happens, your washer will start fine. Your put it for a normal wash, it does its thing, lets in water, and agitate and stuff, but when it goes to the spin cycle. it stays in that cycle and wont advance. Leaving you with a tub full of water. Like i said if its a traditional top load kenmore, the lid switch is the the gray looking part when you open your lid. when you open your lid, youll see two screws holding it. But you have to take the whole shell of the waher to get to it....take 2 screws on the back corners of the counsel, then flip the counsel up. Locate to metal clips and pop them put with screwdriver. unclip the lid switch connector located by the clear hose that runs down. then lift and pull the whole shell towards your and acess the switch from underneath. put back together how you took it apart.( MAKE SURE THE CLEAR HOSE THAT RUNS FROM THE TOP COUNSEL TO THE TUB DONT GET PINCHED BECAUSE YOUR WASHER WILL OVERFLOW WITH WATER) like i said if its a tradidonal top load kenmore....hope this helps
Aug 12, 2009 | Washing Machines
Washer will spin but won't drain automatically
are you sure it spins? usually something is in the pump like a sock. You could remove the front and take the hose off the pump to see if its clear. It also sounds like it could be the lid switch. if you have to close it make sure you hear a clicking noise from the lid switch.
May 14, 2009 | Maytag Washing Machines
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Aug 22, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Whirlpool LSN1000LW Top Load Washer Logo
212 people viewed this question
Dan Webster
Dan Webster
Sal De
