Question about Pioneer DEH-1600 CD Player
Need wiring diagrahm of main plug
I am changing vehicles & I need to know what color, on the plug, goes to which place. I E, White/blue stripe---LR speaker, etc
Thanx in advance Larry McCoy
  • 905 Answers
  • jason Mar 06, 2009
    thank you ! and thanks for using fixya !
Need to know from top left to bottom right what each wire goes to on power plug on jensen car stereo model vm9311
Hi Jeff, Thanks for the question. When wiring an aftermarket car stereo I always recommend purchasing a wiring harness that will connect into the vehicles existing harness, Then you only have to worry about connecting each wire to it's color coded counterpart. With that being said, if you do not have the stock harness I can explain the wiring colors to the best of my memory
Red = 12v Memory power
Yellow = 12v Constant power
Black = Ground
Blue/white = Power Amplifier
Blue = Power antenna
Grey = RF speaker (+)
Grey/Black = RF speaker (-)
White = LF speaker (+)
White/Black = LF speaker (-)
Purple = RR speaker (+)
Purple/Black RR speaker (-)
Green = LR speaker (+)
Green/Black = LR speaker (-)
Sometimes there is a dimmer wire also, usually orange or pink I believe
I hope this helps, & Thanks again!
Feb 18, 2014 | Car Audio & Video
I need to know which wires are what on a Clarion TVX5653 for the main(power) harness. There are 7 wires colored as follows red, yellow, black, blue, blue/yellow stripe,orange, orange/white stripe. Thank...
red is for pawer that goes to the fuse panel
black is for the ground
yellow is a hot wire that goes to the main power or battery it should have a fuse in the line
blue is for power antenna if u need
blue and blue yellow speakers same with orange ,orange/white
Dec 13, 2010 | Car Audio & Video
I dont know what color wires are for what, i had my head unit stolen and now im not sure what wires go to the new kenwood head unit
The three main wires you need to worry about are the
Ground (Black) Battery + (Red) Constant + (Orange)
As far as the speaker wires goes you are going to have to trial and error them. They are usually color coded so for instance one wire is purple with a white stripe there would be a purple wire with a black stripe that would correspond with it. Every vehicle is different in how it is wired. I know installing a stereo looks intimidating but just split up the wires and you will see it is quite simple. Do a professional job and use crimp connectors, going the electrical tape route is never worth the time it saves.
Nov 24, 2010 | Car Audio & Video
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
Need wire color codes for pioneer model DEH-P3001B
If you're installing this the easy way to go is go to like walmart and buy a stereo wiring harness for your specific vehicle. This plug plugs directly into your factory plug and has the wires that connect to your pioneer unit attached to it. All you need to do is match color to color. tracing wires to splice directly into your factory wiring can be a royal pain, trust me i've done it and it ain't fun... but for what its worth here you go.
Red...Accessory
Yellow...power
Black...Ground
Blue w/ white stripe...remote turn on
Blue...power antenna
Gray...Right front+
Gray w/black stripe...right front-
White...Left front+
white w/black stripe...left front-
Purple...right rear+
Purple w/black stripe...right rear-
Green...left rear+
Green w/black stripe...left rear-
Aug 30, 2009 | Pioneer DEH-P2900MP CD Receiver...
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
What are the colors of the speaker wires in a dodge stratus 1997 coming from the wire harness of the car itself
The easiest way is to check the speakers themselves as manufacturers tend to change colors of speakers at a whim. Usualy though you will have 8 wires (4 front & 4 rear) paired in colours (white goes with white+black stripe(stripe is possative on speaker))etc.
Not knowing the cars electrics I can't be more specific.(I live in UK so don't know that much about U.S. cars)
Jun 27, 2009 | 1997 Dodge Stratus
I need the Wiring Diagram for a Sony CDX5070 Car Stereo.
Should have standard aftermarket wire colors ( yellow-12v, red-switched, black-ground, blue w/ white-amp turn on, blue-power ant., White-LF speaker, Gray-RFspeaker, Green-LR speaker, Purple-RR speaker, the ones with the black stripes are negitive)
Apr 27, 2009 | Sony Car Audio & Video
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Pioneer DEH-1600 CD Player Logo
323 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
