Question about Kenmore 63662 / 63664 / 63669 Microwave Oven
Kenmore Mod. 721.80524500 microwave door will not lock.
  • Kenmore Master
  • 9,098 Answers
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Mar 06, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Microwave model 721 62624200
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
Posted on Jul 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: f9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
Posted on May 20, 2009
SOURCE: kenmore microwave model 721-63252301 - no heat
we are going to try to find a fuse and replace that or just buy a new microwave
thank you
Posted on Jun 06, 2009
SOURCE: I have an error code
I would like to repair the kenmore mocrowave myself, it has the error code f-9. Do I need to let the micrwave sit for a wile so the hi voltage can disipate from the inverter or magetron
Posted on Aug 07, 2009
Kenmore microwave model 401.85053010 just stopped working because door will not shut and lock. Does the main board have a safety interlock tie-in for the door?
Most Microwaves have anywhere between 3 and 5 switches to monitor if the door is open or closed. They have to act in proper sequence too. It is a safery feature so you can not run it with the door open.
Aug 18, 2017 | Kenmore Microwave Ovens
Why wont the microwave start after I have repaired the door lock
If the micro switches for the door are not aligning up then the microwave will think the door is not closed and won;t start so I would make sure the door micro switches are lined up
Nov 04, 2014 | Kenmore Microwave Ovens
Shows locked but runs when door is opened
Unplug till fixed ! Replace the 2/3 door switch's inside near where the two locking arms go inside the microwave. get the right ones you can do it.
Apr 12, 2014 | Kenmore 62622 Microwave Oven
Our Kenmore Microwave Hood combo model # 401.88529011 door sticks and is very hard to open off and on
Possible that the door lock is jammed, it can also be due to jamming of the door switch or the plastic lock being stuck on.
You need to remove the front panel , and reset the door assembly.
Jan 25, 2013 | Kenmore Microwave Ovens
Won't heat
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 28, 2010 | Kenmore 63993 Microwave Oven
Model # 721.80823500
f-5 code on kenmore microwave oven means a problem with the door lock switch. Could be a bent latch or latch assembly that’s not actuating the latch switch correctly or that the latch switch itself is bad. Check the door switch, too.
plse do not forget to accept the solution.
May 02, 2009 | Kenmore 63792 Microwave Oven
Remove Kenmore Mod. # 5648598601 from wall.
A lot of those you can replace the bulb without taking it down. There should be screws at the top that lossen up the vent in the front. Remove the vent, might have to open the door and slide it to the left (a little latch) then you should see a filter that just comes out and behind that is the bulb. I would try that before taking it down Forgot to mention that in the other e-mail.
Mar 04, 2009 | Kenmore 80412 Microwave Oven
Microware Kenmore mod. 721-67490790
I don´t know how but it turned on after a while and until now is working good. Maybe it turned off when I was using a lot the microware. Anyway thank you very much.
Liliana Martinez
Jun 14, 2008 | Kenmore 62622 Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Kenmore 63662 / 63664 / 63669 Microwave Oven Logo
198 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
