Question about iLO Televison & Video
Analog or digital
I have a 32''wide screen lcd tv model lct32ha36 is it set up for digital or just analog air signal ?
  • 257 Answers
Hi, Lucky you, your ILO Tv has an ATSC tuner which is digital. This should Fixya!
Posted on Mar 06, 2009
How to switch from analog to digital
Flat panel TV (DLP, LCD, LED or HDTV) are digital already.
Your signal inout could be Analog or Digital.
Also STB (Set of Box) or Cable or OTA (over the Air channels) determine if your input signals are Digital or Analog.\
Aug 10, 2016 | Televison & Video
How do i set tv up with regular antenna
You are not stating what type of TV you have. If it is an older CRT or even some older LCD flat screens, it may only have an analog tuner. All TV stations today are broadcasting digital signals and if you do not have a digital tuner in the set, you will need an adapter box to use an antenna with the set. They were widely sold around the time of the analog-to-digital transition, but are harder to find anymore.
Oct 20, 2015 | Televison & Video
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
How change setting to received a digital signal. Look like TV is in Analog mode. I put a coverted BOX and see TV without any problem but without converted Box, I see a white screen with noise. TV Model:...
U want free air DTV?Yes,have a good Digital antena or a roof antena hood up to ur tv.Goto the tv menu.Goto SETUP go down to Ch.setup enter and pick AIR not CABLE.Enter it again for scanning for DTV free air channels.After done the scanning u should have all the free DTV free air channels.
Jan 24, 2011 | Protron PLTV-32 Television
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
My philips lcd digital tv says I am recieveing analog signals from a digital direct tv sat. How do I get my tv to change to accept digital signals?
First verify that the direct TV satellite box is set to receive and display digital stations. If you old set on the sat was analog, the box may not have been reset. You may have to contact you satellite provider. Next you will have to go to the TV menu and auto program/scan in the stations. This should pick up all the stations.
Mar 16, 2009 | Philips 32PFL5332D 32 in. LCD Television
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Air analog 3 message keeps popping up what does that mean?
I bought the 32 inch LCD tv. I contacted Sharp. Here is there response.
Thank you for contacting Sharp Electronics Corporation.
The display will populate on screen any time there is a change to the incoming signal (mono to stereo audio, weak/fluctuating signal strength). Unfortunately there is no way to deactivate the on screen display. If you are able, try using an alternate connection (composite video and analog audio; yellow, red and white cables) from your source device (cable/sat box, if using) to the unit. This will prevent this issue from occurring by providing a more consistent signal. Let me know if you have any other questions!
Jan 02, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
Televison & Video Logo
101 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
