The turntable was recently disconnected and moved to remporary storage, while new flooring was being installed. When I reinstalled the turntable, the red power light comes on but the turntable does not move. I installed a new belt, but it still doesn't move. Played fine before!
    Sergeant:
  • 250 Answers
Http://www.turntablebasics.com/
click the link.
also check out this 12 steps in the another link  http://retrostereo.net/_wsn/page7.html
 MOVING
      When moving your table there are a number of steps you need to take to pack your table carefully including securing the platter and tone arm, removing the needle and wrapping the lid and table in bubble wrap. Tables, lids and needles are easily damaged in transit if not secured and should be readjusted once moved.
Posted on Mar 06, 2009
  • 19,396 Answers
Check the mechanics and the internal circuit , it is in errors state.
Posted on Mar 05, 2009
  • Ginko
    Ginko Mar 06, 2009
    The turntable had been moved, and this could have caused an already existing fault like a bad soldering joint popping up.
    Try to hear if the motor is starting, if you hear the motor check that the belt is well in place (if not direct traction model).
    If the motor dooes not start then it is a lose contact either on the motor side or on the switch side.
    If the unit had not stayed on wet place, the most common damage by moving is a broken contact.
How do you remove the lower center console on a 2000 Olds Intrique
Item Part Number Description 1 060024 Floor console armrest 2 06010 Floor console storage bin 3 04338D Floor console finish panel (front) 4 044D90 Floor console finish panel (center) 5 - Floor console cup holder screws (2 required) 6 13562 Floor console cup holder 7 - Floor console front screws (2 required) 8 - Floor console rear screws (3 required) 9 - Floor console nut 10 045A36 Floor console Removal and Installation
  1. Position the seats as needed to remove the console.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the floor console storage bin.
    1. Remove the 3 screws and the armrest.
    1. Remove the floor console storage bin screw.
    1. Remove the pin-type retainer.
    • Disonnect the electrical connectors.
  1. Remove the floor console front finish panel.
    • Pull upward from the front of the trim panel to release the retainers.
    • Disconnect the electrical connectors.
  1. Remove the floor console center finish panel.
  1. If necessary, remove the 2 screws and the floor console cup holder.
  1. Remove the 2 floor console front screws.
  1. Remove the 3 floor console rear screws.
    • To install, tighten to 4 Nm (35 lb-in).
  1. NOTE: Lift the console from the rear and slide it rearward to release the rear seat heater ducts from the instrument panel. Remove the nut and the floor console.
    • Disconnect the electrical connector.
    • To install, tighten to 8 Nm (71 lb-in ).
  1. To install, reverse the removal procedure.
Jun 10, 2015 | 2000 Oldsmobile Intrigue
How can i use a pioneer PL-Z93 turntable with a pioneer A-717 amp?
Hi, there is no reason for the turntable not to work with your amp. This amp has 2 phono inputs. Moving magnet and moving coil. Your tt likely has a moving magnet cartridge fitted so connect via that input. Cheers John. styluscity.com
Nov 14, 2011 | Audio Players & Recorders
On start up the computer asks for normal start up then goes through system checks and says its deleting 93 files then shuts down and re-starts to pull up a blank screen but the mouse icons stays running...
You will need to reinstall the operating software as there is delection of the program software which could have resulted in infection of some malware or virus.
If you have the recovery disk try to use it and reinstalll.
Once program is reloaded make sure that a good antivirus is installed, keep cclearing up the cache, the remporary files, cookies and history.
Sep 05, 2010 | Dell XPS M1530 Notebook
Computor does not see the turntable
It is likely that the driver has been deleted. If you cannot reinstall the driver you could do a system restore. Click the start button, accessories, system tools, system restore. The computer will pick a recent date but you have an option to pick your own date. Select a date, in bold, when you know that the turntable was working and select ok. When the System restore has completed your turntable should be working again. This will remove any programs added after that date but will not affect your documents.
Jul 19, 2010 | ION Audio iTTUSB Turntable
Old Philips turntable 312 No sound
I am in a similar situation. I recently discovered that exact model turntable in our storage room. The Philips 312. While looking it over, I noticed the stylus is broken. I was wondering where you purchased yours?
Mar 27, 2009 | Philips Audio Players & Recorders
LP Turntable
the platter must be able to spin freely without a belt installed as shown in this video
http://www.archive.org/details/Turntable_Belt_Installation
that would be one likely cause presuming you have the correct new belt that is.
Oct 26, 2008 | Panasonic Technics SL-DZ1200 Turntable
Turntable
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Feb 20, 2008 | Aiwa Z-L500 Shelf System
Trouble getting new turntable to work
make sure the belt is installed correctly, you can go to sony.com and get the assembly manual right there
Dec 25, 2007 | Sony PS-LX250H Turntable
YAMAHA CD PLAYER WON'T PLAY
GG  My kids had a PlayStation 2 that did this and so did my AIWA 3 CD player.  The solution for the PlayStation was to remove the cover use alcohol and clean the lens of the laser reader.  They get dust on them and simply cannot read.  The AIWA required replacement of the laser which cost almost as much as the unit and didn't last 6 months.
Oct 17, 2007 | Yamaha CDC-565 5-Disc CD Changer
62 people viewed this question
 Grubhead
Grubhead
