Question about Amana ACO1860 Microwave Oven
Handle The "stanless steel" has come unwrapped on the handle...I need to replace handle or the entire door?
  • patsimmonsco Mar 06, 2009
    Amana aco1860as
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
  • Amana Master
  • 9,030 Answers
For this model the handle is indeed available separately.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Mar 06, 2009
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Door handle broken. I want to find a replacement handle without replacing entire door.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance.
NOTE: I would need a MODEL NUMBER in order to determine if your appliance repair parts list the door as an entire assembly, or if you can purchase the handle separately. You can also view the websites I have listed in the link provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 05, 2011 | Microwave Ovens
I need a new door for this microwave. I have been looking online for hours and can't find just the door. Can anybody give me a website that sells just the door for this micro? Thanks....
The door is available at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number you listed this question under is correct, the part number for the ENTIRE door is WB56X10585.
Is there a reason for replacing the entire door? You can purchase individual replacement parts if only a single part on the door is broken. The first three sites on the list have helpful exploded view diagrams to assist you in locating and properly identifying the parts you may need.
The most common thing that fails on these doors is the door handle. If only the handle is broken, the door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part numbers for the handle on this model are (2 pieces):
WB15X10119
WB15X10120
If you have any questions, please post back with your and let me know. I hope this helps you
May 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for replacing door handle on kitchenAid microwave oven model KHMSi55LSS0
Remov fan cover, bottom plate, you can either do it right and pull out the entire plastic baffle to reveal the hindge bolts or you can just jam something between just enough to get a long socket on a small socket wrench. You must replace the entire door. Trying to replace just handle is almost impossible.
Feb 13, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The door handle on my GE Spacemaker XL model JVM1330BW 003 broke off so I decided to replace the entire oven. Can you recommend a replacement that will fit into the same recess and have the exhaust vent...
If the outer door is not broken. All you have to do is replace the handle. You will need to access the door handle mounting screws and remove them to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. The part number for the door handle is WB15X10020. If the outer panel is damaged, you may have to replace the entire door. The part number is WB55X991. The cheapest web source I have found the handle listed is appliancepartspros.com for $47. The entire door, however, sells for $110 at pcappliancerepair.com.
The RF inside the cavity of a microwave oven is actually controlled by the RF shield in the glass. As long as the glass is intact and the inner door facing is not bowed, warped or cracked, you will not have to worry about RF leakage (even with the handle broken off).
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 03, 2009 | Microwave Ovens
How to fix a broken handle?
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
NOTE: If your microwave is the same model you have this listed under, I could only find one website that offers the handle as a separate replacement without purchasing the entire door (the entire door cost over $200!). The handle lists for about $51 at repairclinic.com. You can search around, but I have already tried the following sites:
repairclinic.com
Aug 12, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
The entire door handle snapped off
I have the same problem- funny when we built we went all Maytag and got a bunch of lousy handles- the stove, micro, fridge, and freezer... I glued the pieces of the handle together and used plumber's putty to fix it. It's MightyPutty, but without the repackaging and cost. Just knead the putty until mixed, fill the cavity of the handle and press on the door where it was... No problem after six months so far.
Nov 30, 2008 | Maytag MMV5207A Microwave Oven
GE Profile Spacemaker XL1800 Microwave Model # JVM1870SF001
(I also replied via e-mail)
Sorry, but the subject lines get cut off after so many characters.
Thanks for replying.
Part # DE63-00204A looks like a valid Samsung part number but it doesn't show up anywhere, so it's likely a proprietary part made only for GE and not available separately.
You can see a helpful exploded view of this model here.
Then you can go here and enter your model number and come up with the parts list. This site has much better prices than GE.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Chances are you will end up having to but more than you want to, but not the whole door.
Sep 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace GE Spacemaker XL1400 door
On most microwavre ovens all you have to do is open the door all the way and lift straight up at the hinges. The door comes right off the hinge pins. In some cases you may have to remove the top louver panel (right above the door). You should NOT have to unmount the oven to complete this. In fact...I would not recommend it.
Is this a simple matter of replacing a door handle? If you need to only replace the door handle, you just lift slightly on the INNER door plastic around the glass and you will be able to access the door handle screws. There are a series of small grooves in the panel that you can use a small screwdriver to gently pry. You should not have to remove the entire panel. Just open it enough directly behind the door handle. Be careful when prying on the plastic. It can break if you're not careful. I hope this helps you.
Feb 27, 2008 | Microwave Ovens
Amana ACO1860 Microwave Oven Logo
146 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Mike
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
