It's a two way communications radio, not a broadcast radio, hence it won't receive FM/AM broadcast radio stations.
You should not confuse the two as they work on different radio bands, most FM broadcast radios are on the 86-108MHz bands, whereas two way radios operate on the following bands: 1-86MHz, 108-174MHz, 220-520MHz & 865-920MHz
I don't know which band your radio works on, but not broadcast bands I'm sure.
The only exception to this is the smaller hand helds, which may have FM broadcast programmed, but if this is the case with yours, This issue is out of the realm of two way radio queries, as Broadcast radio is not two way radio, but one way radio, and I'm not competent enough to answer Broadcast radio issues.
i had a simular issue and it ended up being the power lock switch was stuck on my liftgate. also could be the linkage is jammed/bent or the little plastic keepers that hold it together came apart
inside glove box there should be a sticker with the radio serial number and code. if that has been removed then you could try the honda owners site. you'll need the vin # and some other info I was able to get the code recently for my 2010 CR-V
Sounds like the CD changer is defective, sometimes the dealer will offer a "one time goodwill" repair when it is out of warranty for miles but not for the time period. Check with the dealer where you purchased the car.
The wiper phenomenon you described is normal. It's a really cool feature. The car knows that you're moving so the wipers adjust to your speed.
The headlights and radio light problems you described is probably a bad battery. I didn't know about it either until I took my 07 CRV for it's 15k mile maintenance and they tested the battery. They said the battery was defective and wasn't putting out enough power so they gave me a new battery. Since it was under warranty, it didn't cost me anything.
THIS SOUNDS LIKE YOU HAVE A RADIO PROBLEM. IT MAY BE WORTH YOUR TIME TO HAVE A DODGE DEALER CHECK THE RADIO TO SEE IF INDEED THE RADIO IS BAD, BUT THEN YOU HAVE THE OPTION TO REPLACE THE OEM RADIO WITH A NICE AFTERMARKET RADIO. THESE HAVE COME DOWN IN PRICE DRASTICALLY AND ARE PROBABLY CHEAPER THAN REPLACING THE OEM RADIO. WITH NO SIGNAL OR STATIC ON THE AM BAND SURE SOUNDS LIKE THE AM BAND IS DEAD. IF I CAN HELP MORE REPLY TO: ARCLIGHT1217
Thanks for your help.
