Question about Uniden Cordless Phone
HOW CAN I CHANGE FROM PULSE DIAL TO TONE? - Uniden Cordless Phone
  • 4 Answers
Email me your model # and i will email you a solution
Posted on Mar 07, 2009
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
The tone on my 2 portable DECT 6.0 phones was somehow changed- now every time I dial, I get the old rotary sound and I can not access any menu options. Help, I use my phone for work and need it fixed! ...
Your phone is somehow set to pulse dialling and you need to change it to tone. Instructions are given below.
Of course if you can't select menu options this will not work so please explain why the menu options are not available - what happens when you select the menu softkey?
Dial mode
The dial mode is preset to tone. If you do not have touch tone service, you need to change the setting to pulse.
To change the setting:
Press the MENU softkey when the handset is not in use.
Press or to select SETTINGS, then press the SELECT softkey.
Press or to select Dial mode, then press the SELECT softkey.
Press or to choose Tone or Pulse. Press the SET softkey to save, or press the BACK softkey to exit to the previous menu.
Feb 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Have an Emerson cordless phone EM6113-BK. We can
On that model you need to press and hold the FLASH button, after it beeps it will be in tone mode and not pulse.
Apr 16, 2010 | Emerson Smartset Clock Radio
I dont have an owners manual and just wondering how to switch the setting from pulse to tone
  1. Press MENU/SELECT.
  2. Select the Global Setup menu, and then the Dial Mode submenu.
  3. Scroll to highlight Tone.
  4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to pulse dialing, follow the same procedure, but select Pulse in step 3
Jan 09, 2010 | Uniden DECT 6.0 Cordless Telephone...
Won't dial out
might you have your phone set for tone on a pulse line???
Do you know what kind of line you have?
You can use pulse and/or tone on a tone line. But you cannot use tone on a pulse line.
A pulse line is cheaper ... I have a pulse line from the mid 70's and I refuse to upgrade it (costs more) to tone - whats the point - I never get any calls and im not in that big a hurry to dial for the extra couple bucks they want.
Oct 13, 2009 | Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
I HAVE A UNIDEN DECT 6.0 PHONE THE HOUSE AND IT WITH NOT DIAL OUT OR LET INCOMING CALL COME IN PLEASE HELP ME WITH THIS PROBLEM ! MY NAME IS JULIUS C FREDERICK MY NUMBER IS 803-741-0511 EMAIL IS...
Dial Tone comes back even after I dial the phone!
Question:
Why does my phone allow me to dial a number, hear the numbers being dialed and then go back to a dial tone? Help me I want to call out!
Answer:
Sir the you are dialing on needs to have the other dial mode in operation. You have the ability to change dial mode on your phone. Instructions to change dial mode are usually at the beginning of the manual under install /set up the phone. If you are currently using pulse, please change the mode to tone. If using tone please change the mode to pulse. Doing this will allow you to call out.
answer found on www.uniden.com
Sep 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Oct 19, 2007 | Uniden DECT 6.0 Cordless Telephone...
Uniden Cordless Phone Logo
118 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
