Question about Kenmore 62622 Microwave Oven
Kenmore microwave making loud buzzing sound.
Kenmore 721.62469200 model microwave, makes buzzing sound when running, turned off asap. Removed cover, tested unit, saw a flash in the area of the magnatron, when it buzzed, only let buzz 1-3 seconds. Capacitor did not check shorted, but, my meter only goes to a 1000 ohms. Magnatron also did not check shorted to ground, shorted pin to pin. Diode checked open both ways need to get another meter for better test. Could diode or capacitor cause the buzzing sound or do I need to get a magnatron. Thanks Frank
  • sg788fg Mar 06, 2009
    Problelm was daughter made a mess and cleaned out the microwave, When she did the cleaner ran behind the plate over the wave guide hole. Food was burnt on the plate causing the arcing sound. Thanks for the information it was a great help. Frank
  • William Miller
    William Miller May 11, 2010
    Chances are it is grease or food debris arcing on or behind the waveguide cover / stirrer cover, on the stirrer or in the waveguide.
    Or it may be that the stirrer is not turning.
    You can check that by removing the stirrer cover and running the oven a few seconds.
    Running it empty a few seconds is a good way to find where it might be arcing.
    Once you check all this, let us know what you find.
  • Kenmore Master
  • 9,085 Answers
Posted on Mar 06, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Microwave makes a loud buzzing noise
The buzzing sound could be from loose laminations on the high voltage transformer, or from loose mounting screws for the transformer. This requires investigation by a qualified technician as there are lethal voltages associated with the transformer. It could also be from a loose cover. First check that all the cover screws are tight.
Mar 21, 2014 | Electrolux Microwave Ovens
Kenmore Over the Range Microwave making buzzing sound and not heating
This is a strong indicator the magnetron is fried, also! this is the most expensive part to replace in the microwave oven, and in most cases cheaper to replace the whole unit.
Jul 18, 2012 | Microwave Ovens
My microwave no longer heats anything and also makes a really loud buzzing sound when i attempt to use it.
The problem is most likely caused by a defective magnetron that "heats the food" is loading down the high voltage transformer causing it to make a loud buzzing sound. The cost to repair (depending on make and model) will probably approach the cost of a new microwave oven when you factor parts and labor.
Jan 23, 2011 | Microwave Ovens
Kenmore microwave Model No. 721.62463201 runs but does not heat and has a terrificately loud buzz. All lights displays are normal
Hello there:
There's no heat, but it buzzes loudly When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. I recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
And if you have your warranty for this you can use it to ok
Hope this helps best regards mike
Nov 19, 2010 | Kenmore Microwave Ovens
My microwave makes a loud buzzing sound
Magnitron is going out. Suggest discarding microwave it will possibly go completely out in the near future. Good luck hope this helped
Dave
Nov 02, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Microwave making loud noise behind control pad and won't heat
Sounds like the magnatron (the bit that creates microwaves) could be goosed. Remove outer cover ( Isolate from the electric supply then remove screws at bottom on the sides).
Find big lump that says on magnatron with model nos etc on, any good electrical supply shop ( Maplins etc) should stock new one.
It is easy to change. It took me about half an hour having never done one before.
Buyer beware the price of the parts could be in excess of a new microwave.
Shop around
Sep 15, 2009 | Panasonic NN-T993SF Microwave Oven
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Microwave buzzing
It's likely a bad magnetron or maybe the high-voltage transformer. If it's within the warranty period of the magnetron (5 years or less), I would call Sears. In my professional opinion, no one should work on a microwave unless they are fully informed and aware of the deadly hazards and necessary precautions. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Mar 21, 2007 | Kenmore 62622 Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
2,504 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
